Topic: rating buttons (Read 2241 times) previous topic - next topic
rating buttons
Hi, hard task probably - but is it possible to add buttons (saying 1--5) that change the RATING tag to the number pressed on the toolbar (for the currently playing item, and if there is none, the currently selected track)? Thanks in advance
err... i'm not using windows any more ;)
rating buttons
I dont know about using the default UI, but under columns ui it is possible.  I just did it the other day.
I set up 5 scripts in masstagger that set the ratings to values 1 - 5.  Then I added buttons for each by right clicking on my buttons in columns ui and selecting customize.
I then added buttons and changed their command to
command group: Context Menu Items
command: Tagging/Scripts/Rating = 1
item group: current playlist selection
I changed all the buttons display to "Text", and made checked the "use custom text" and renamed all of them to 1, 2... 5.
There used to be a link to my website here.
rating buttons
Thanks, it worked!
