Topic: foobar2000 1.6.7: Feedback concerning the ReplayGain Scanner preferences (Read 428 times) previous topic - next topic
I have some feedback/suggestions concerning the ReplayGain Scanner preferences as of foobar2000 1.6.7:
  • As you can tell from the attached screenshot, the help text for the True peak scan configuration seems to be cut off. I would appreciate it if you could look into this and restore the full text.
  • Would it be possible to extend the RetroArch resampler such that it is possible to choose an auto x2, x4, x8 upsampling instead of dialing in a fixed target sampling rate? Right now we cannot really use the RetroArch in an auto upsampling configuration for the True peak scan resampling and I find this rather unfortunate as I quite like this resampler.
  • While this is similar to an existing request posted on the foobar2000 forums concerning the possibility to configure the default resampler in the advanced options, I would appreciate if the ReplayGain Scanner preferences would also allow to configure the quality settings of the default resampler if one of the auto settings is selected. (Note that the Configure button for the True peak scan resampler is grayed out because of me selecting the auto x4 oversampling option.)
Thanks in advance for considering my feedback!
Kind regards
Re: foobar2000 1.6.7: Feedback concerning the ReplayGain Scanner preferences
Thanks for your feedback.
Truncation fixed for 1.6.8.
Default [auto] modes already use RetroArch.
As for being able to specifically configure details for auto modes, request noted.
We are the bork. Your software bugs will be added to our own. Resistance is futile.
