Topic: Peakmeter Spectrum not showing up (SOLVED nvm I'm just dumb) (Read 185 times) previous topic - next topic
Yesterday I had no trouble installing it and everything was working, but now it's not showing up when I try to replace an element even though it says it's installed.
Hhhmmmm Croissants.....
Re: Peakmeter Spectrum not showing up on "replace element".
Element implies you're using default UI whereas the component seems to be for Columns UI??
That is kind of weird. I have always used this component on default UI? Is there a different component which is exactly the same for DUI? Maybe I'm confused?
Ok turns out I'm just really dumb (don't do monster energy drinks kids!).
Turns out this was the component I was using: https://hydrogenaud.io/index.php?topic=97404.0
It's called musical spectrum. I have no idea how I got confused, I was sure I was using a different link.
