Topic: Get Covers (Artwork) radio logos (Read 16008 times) previous topic - next topic - Topic derived from Re: Biography Text, A...
"Get Covers (Artwork) radio logos"
version "24032018"
previous, next img. - mouse wheel on the img;
img. interval setting - Shift + mouse wheel on the img;
UR5EQF. Ukraine
Re: Get Covers (Artwork) radio logos
I can not find any download link for the code - is that intended?
Thanks, very nice script!
Works well with the WSH panel, only thing I saw is that manual previous/next image scroll freezes quite often, refresh solves the freeze.
MojoBass, how do you think this can be corrected.
UR5EQF. Ukraine
kgena_ua, unfortunately I am not a programmer - meaning: I have no idea...
Sorry. Where I paste the skript? Or rather, I need a special component for operation?
muxx,
You need:
foo_uie_wsh_panel_mod
or
foo_jscript_panel up to version 2.0.0.
UR5EQF. Ukraine
Ok, thanks! I have WSH Panel Mod 1.5.6 (no newer version found, actually I can find not any download resource). Must I import the .txt file in it? But the WSH import feature looks only for .cfg files!?  :-[
muxx,
txt file - open - select all - copy;
WSH panel - paste - apply.
UR5EQF. Ukraine
version "29032018"
some fixes
thank you.
would be nice if there is an automatic download missing album art option.
I thought that was what this did?
If not then what does this do? Foobar is able to show the artwork for local songs. Is it unable to do so for live streams (I thought foobar supported Ogg Opus and Vorbis streams). Does this add artwork support for shoutcast since you mention radio?
Does this reference a online database of artwork?
I description of what the plugin actually does would be nice.
how to use it with Spider Monkey Panel?
hello Mrakobes.
If there is interest, then I will adapt the script.
Temporarily use the script "Biography, Covers, Albums, Title, Similar artist, Lyrics info.www.last.fm.".
There is an opportunity to view the covers.
UR5EQF. Ukraine
Hi, thank you for responding so quickly. I asked in another topic
https://hydrogenaud.io/index.php?topic=116669.msg996586#msg996586
In general, I know this is possible in your script - you need to configure the display of any image files with any names that are located in the "covers" folder, which is either in the album folder or on the level up, if the audio storage structure implies the presence of "CD1"
.... script to search for images in the "Covers" folder, which is located in two versions
1. In the same folder with the album
2. One level above the album being played, when listening to a two-disc edition, it is located in the album folder
Script "Get Covers (Artwork) radio logos" do it.
UR5EQF. Ukraine
Then go under the spider monkey, a very-very-very big request!
version 10052021
For Spider Monkey Panel.
UR5EQF. Ukraine
Hi my friend, thank you very much! Tell me how to change the code so that it only looks at the folder "Covers"
var root_folders = ["cover", "scan", "art", "img", "images", "pic"];
I also want to create a file with a different resolution but with the same name, only "Logo" In the root folder of artist
I also want to understand how and from which photo is displayed, how many and what photos are in the folder, in the form of a list or thumbnails
Hi.
The figure 'get covers.png' shows the scheme of how the script works.
The figure 'img path.png'
it needs to be done.
It is possible to make a menu item with a list of folders from which images are taken with the number of images in the folder.
UR5EQF. Ukraine
@kgena_ua
Hi, and what lines should I delete so that the script does not get into folders with music files? In general, I ONLY looked at the "Images" folder
and how else to make the image size 1:1 and decrease if it does not fit into the screen size, i.e. 400x600 does not need to be stretched, and UHD reduced
