Topic: Default UI Gallery (Read 707846 times) previous topic - next topic
Re: Default UI Gallery
Reply #601
I probably should distribute a bottom panel like that with JSP3 itself. I've been too lazy to incorporate a volume slider in the current track info/seekbar/buttons scripts.
Yes, that would be an interesting addition. Of course, you can complete anything as basic as this in no time.
But if you don't have the time, here is the script I use. As you know, I'm a newbie, and there must have been a joke line code in the script.
eurekagliese, looks good!
Thank you, and thank you for your Flags script, which I could learn from along with the JSP samples.
Thanks for the tip seperating shuffle/repeat buttons!
Reply #603
@eurekagliese
JSPlaylist:
Enable Dynamic is valid only during playback
Enable Dynamic only when Now Playing:
Can you add an enable/disable option?
Now Playing
Stop
SHURE SRH1840, SENNHEISER HD660S, Beyerdynamic DT 1990 PRO, HIFIMAN HE5se, Ultrasone Performance 880, AKG K712 PRO, SONY MDR-1AM2, Bowers & Wilkins P7 Mobile Hi-Fi, Bose QuietComfort 45, SONY WH-1000XM3 (made a Upgrade/Balanced Cable by myself) Shall I write more?
Re: Re: Default UI Gallery
Reply #604
Thank you; in fact, I was inspired by the Elia theme, which resembles Spotify.
By the way, your Vibe theme is also really good, clean and elegant.
Reply #605
@eurekagliese
JSPlaylist:
Now Playing
Stop
Actually you can just simply switch the uncomment line 966 to
	// var metadb = fb.GetFocusItem();
var metadb = fb.GetNowPlaying();
Reply #606
Great.
Reply #607
X
Reply #608
X
Reply #609
So my theme end up as below (with JScript Panel 3)
Reply #610
Here is my humble DUI configuration (v2.1 preview 2023-08-28 32-bit).
