Topic: foo_quicksearch (Read 231111 times) previous topic - next topic
Re: foo_quicksearch
Reply #426
NEMO7538, reg. CUI Reply #7911 and CUI Reply #7918
I want to to change the font size used in the Quick Search Toolbar.
Can you add it in Options like Custom Colors, or make Quick Search Toolbar available as item in the CUI fonts settings, see picture ?
X
Re: foo_quicksearch
Reply #427
I'm thinking about a port to 2.0 / 64 bits ... when I have time and courage.
Thanks for your patience.
If you ever update this, would you consider allowing larger custom bitmap? Currently it's limited to 40x16px which does not scale well for 2160p resolution.
Re: foo_quicksearch
Reply #428
Hi NEMO,
Quicksearch is (was) a great tool for all foobar user. Now I'm missing it desperately for 64-bit. How can we encourage you to port it to 64-bit?
Antares
Re: foo_quicksearch
Reply #429
@ NEMO7538,
Any news about this Plugin?
Re: foo_quicksearch
Reply #431
please let me know when the 64 bit version is out
Re: foo_quicksearch
Reply #432
Hello,
With the very kind help from rtldg the quicksearch toolbar has been ported for compatibility with foobar version 2.0 and newer.
It can be downloaded as usual from foobar components repository and now contains 32 bits and 64 bits version.
As it is a new build, please report any issue or comment.
In particular we would appreciate a test with column UI if anyone is using it with the component.
Re: foo_quicksearch
Reply #433
Thank you very much for the update. It's working as expected on default UI x64.
Re: foo_quicksearch
Reply #434
thx a lot for this :-)
2 little bugs found: 1) after open and close: pointed (with mouse/keys) items in a fat font
                              2) properties are not in dark mode
and a little request: is it possible to place quicksearch in toolbar?
Re: foo_quicksearch
Reply #435
The font issue is a bug already reported in this thread. I guessed at what the cause is. Only the developer knows for sure...
https://hydrogenaud.io/index.php/topic,125362.0.html
And Default UI does not allow 3rd party toolbars.
Re: foo_quicksearch
Reply #436
thanks Marc for the information - I overlooked the font bug :-(
Re: foo_quicksearch
Reply #437
I'll be looking into that at some point. Thank you for the thread link btw marc2k3.
Unfortunately. I messed around with the SDK's new dark-mode helper hook stuff but some window elements didn't want to be colored so I disabled it and left it for another time.
If marc2k3 says it's not possible (with Default UI) then I guess not haha
Re: foo_quicksearch
Reply #438
The font issue is fixed for the next release.
Columns UI returns an HFONT from CreateFontIndirect() which is deleted with DeleteObject() but foobar's query_font_ex(ui_font_default) apparently returns the HFONT used by foobar, which was being passed to DeleteObject() when the Quicksearch window is closed.
I made it create a duplicate HFONT so it no longer clobbers foobar's.
Re: foo_quicksearch
Reply #439
The repository is now updated with the latest version : V3.8, incl.
Re: foo_quicksearch
Reply #440
thx for updating :-)
