Topic: foo_youtube (Read 511799 times) previous topic - next topic
0 Members and 7 Guests are viewing this topic.
Re: foo_youtube
Reply #1575
This works like a charm! One minor thing, update 3.9 mentions adding yt-dlp support. I have yt-dlp installed via winget, so it is in some obscure folder BUT it is very definitely on the path via "yt-dlp". The component says it is not on the path, which means it is probably checking for the wrong command. I can add it by specifying the executable directly, but I thought I would mention it.
One thing I have been wondering about, is support for YouTube Music on the roadmap at all? As in, playing my YTM playlists including "Liked Songs" which is not a public playlist, and playing music I uploaded into my account? Those songs are also not available publicly at all, if you share a playlist those songs will not work. The audio quality available on YTM is also superior to regular YT, it has some 256kbps vbr aac IIRC vs the 120 or so vbr opus. So yeah, just wondering if that is somewhere on the roadmap or if the plan is to stick to regular YouTube. YTM doesn't have any decent integration anywhere as far as I know, so it would be a first as far as I can tell!
foobar 2000 (foo_youtube)
Reply #1576
how to fix Unable to open item for playback (Youtube Source: foo_youtube: client error: SSL connect error (35) | ffmpeg: Error number -10054 occurred | foobar2000: Network error):
"www.youtube.com/..............."
Re: foo_youtube
Reply #1577
Hi, @3dyd
1、The LAVFilters and madVR loaded in the foo_youtube maintenance interferes with the playback of DVD-Audio ISO files, which leads to a large amount of CPU usage and unresponsiveness of the foobar2000 window.
2、Background image, set to cover can only display the embedded image, can not display the cover.jpg in the file directory.
Re: foo_youtube
Reply #1578
How do you add a custom metadata tag which contains spaces in the tag name?
For ex. this fails: (the album artist part)
fy+https://www.youtube.com/watch?fb2k_album artist=aretha+franklin&fb2k_artist=Aretha+Franklin&fb2k_search_title=Aretha+Franklin+-+Respect+%28Official+Lyric+Video%29&fb2kx_length=151&fb2kx_title=Respect&v=A134hShx_gw
But also this:
fy+https://www.youtube.com/watch?fb2k_album+artist=aretha+franklin&fb2k_artist=Aretha+Franklin&fb2k_search_title=Aretha+Franklin+-+Respect+%28Official+Lyric+Video%29&fb2kx_length=151&fb2kx_title=Respect&v=A134hShx_gw
And this:
fy+https://www.youtube.com/watch?fb2k_album%20artist=aretha+franklin&fb2k_artist=Aretha+Franklin&fb2k_search_title=Aretha+Franklin+-+Respect+%28Official+Lyric+Video%29&fb2kx_length=151&fb2kx_title=Respect&v=A134hShx_gw
Using '_' instead of space, percent encoding or '+' remap it to the wrong tag.
Re: foo_youtube
Reply #1579
Tell me why, after executing the “Full Screen” command, a second window appears in the taskbar and does not disappear until the end of the session, this is extremely inconvenient and annoying. Does this happen to everyone or just me?
YouTube Music
Re: foo_youtube
Reply #1580
Hi, I found a work-around related to "Unable to open item for playback (Youtube Source: Analysis, no video found on Youtube URL):".
I can make the track live again by clearing the cache. View > Youtube Source > Analysis Cache > Wipe Cache.
Hope this help and not repeat with previous post.
