Topic: don't show: foobar2000 was terminated abnormally last time. (Read 4349 times) previous topic - next topic
I'm using Foobar2000 on my HTPC with my iPhone. This works, modulo some bugs, pretty well
But Sometimes I'm just lazy and just reset my HTPC (no proper shutdown). When next time the computers starts, Foobar2000 won't start and gives the annoying popup:
- Start in safe mode
- Check online troubleshooter
- Start normally
So I would like to start always normally. I don't care about this abnormally termination!
Someone has an idea to solve this? It didn't find an option to turn this 'feature' off nor there is a commandline argument to force normally mode.
And no, always proper shutdown is not possible.
Start foobar2000 using a batch file that erases the "running" file from the configuration directory before starting the player.
Note that if you aren't using something like foo_jesus, your playlists and configuration aren't being saved since this normally only happens on a proper shutdown.
Yeah, that I was looking for. But where can I locate the "running" file?
edit: %USERPROFILE%\AppData\Roaming\foobar2000\running
If I don't change the configuration in that 'session', there is nothing to save?
So easily solved after all. THX!
