Topic: Help with filters (Read 750 times) previous topic - next topic
Help with filters
The task is to display the path in the filters, or rather part of the path - the folder in the middle of the path
Eg: g:\Audio\Metal\Swallow the Sun\2021 - Name Album
My music is sorted on the disk by genre - I want to sort genres without nested and parent folders, how to experiment with variables?
%_path% / %_directoryname%
Re: Help with filters
$directory(%path%,1) or $directory(%path%,2), change number according to path depth.
@jazzthieve, Unfortunately, it does not work - different levels are displayed in a mix, despite the fact that the directories have the correct nesting levels, how can a given number of levels be cut off BEFORE and AFTER
It makes no sense for the code to display differing results. It will always give the exact path depth for every path based on the path depth in the code. If the results are a differing mix then simply your nesting structure is not consistent.
Could you give examples, full paths, of where you get different results?
