Topic: EAC detects weird gaps length, can't rip disc as a whole (Read 2005 times) previous topic - next topic
I have an old audio CD-R that I want to rip using EAC, but when I'm detecting gaps (Secure, Detection method A), I get these results:
(tested on multiple drives, same results)
And when I open files ripped with that gaps in Audacity and go to the end (track 3 for example) I see this, which I think is beginning of the next track and which length is around 0:00:00.013:
Is it EAC's fault, or is it burning software's fault and I can't do anything about it in EAC?
Another problem I have with this CD-R is that I can't rip it as a whole without getting errors or CRC mismatches, for example log for track 2 when tried to rip as a whole:
Exact Audio Copy V1.3 from 2. September 2016
EAC extraction logfile from 5. July 2017, 8:29
XXX / XXX
Used drive  : HL-DT-STCD-RW GCE-8527B   Adapter: 1  ID: 0
Read mode               : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 6
Overread into Lead-In and Lead-Out          : Yes
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 1024 kBit/s
Quality                         : High
Add ID3 tag                     : No
Command line compressor         : D:\Programy\Exact Audio Copy\Flac\flac.exe
Additional command line options : -8 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "PERFORMER=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "ALBUMARTIST=%albumartist%" -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" -T "COMMENT=%comment%" %source% -o %dest%
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  5:34.69 |         0    |    25118
        2  |  5:34.69 |  1:08.00 |     25119    |    30218
        3  |  6:42.69 |  1:37.08 |     30219    |    37501
        4  |  8:20.02 |  4:37.06 |     37502    |    58282
        5  | 12:57.08 |  3:56.51 |     58283    |    76033
        6  | 16:53.59 |  2:20.28 |     76034    |    86561
        7  | 19:14.12 |  5:02.33 |     86562    |   109244
        8  | 24:16.45 |  2:59.45 |    109245    |   122714
        9  | 27:16.15 |  5:18.03 |    122715    |   146567
       10  | 32:34.18 |  3:57.68 |    146568    |   164410
       11  | 36:32.11 |  4:31.42 |    164411    |   184777
       12  | 41:03.53 |  2:28.45 |    184778    |   195922
       13  | 43:32.23 |  3:04.73 |    195923    |   209795
       14  | 46:37.21 |  1:35.07 |    209796    |   216927
Track  2
     Filename XXX
     Peak level 96.9 %
     Extraction speed 0.0 X
     Track quality 96.7 %
     Test CRC F851DE7B
     Copy CRC EB3AF6AF
     Track not present in AccurateRip database
     Copy OK
And when ripped as a single track:
EAC extraction logfile from 11. July 2017, 13:56
XXX / XXX
Used drive  : PIONEER BD-RW   BDR-209M   Adapter: 1  ID: 1
Read mode               : Secure
Read offset correction                      : 667
Gap handling                                : Not detected, thus appended to previous track
Quality                         : High
Add ID3 tag                     : No
Track  2
     Filename XXX
     Peak level 96.9 %
     Extraction speed 3.9 X
     Track quality 100.0 %
     Test CRC 641BA7E1
     Copy CRC 641BA7E1
     Copy OK
None of the tracks are present in the AccurateRip database
No errors occurred
End of status report
---- AcoustID Plugin V1.2.0
Total fingerprints: 1
==== Log checksum DB7E8AAD203D23833F02B1817B72634A7C543391A06C8A35E1AB944D7EF1D549 ====
Tried to rip it on multiple drives, same results.
What's going on with this disc and how I can rip it properly? Thank you for help.
Re: EAC detects weird gaps length, can't rip disc as a whole
Not EACs fault. It may also be this CDR was burned from mp3 files that were decoded without gapless handling or the cd was burned from non CD files not ending on frame boundaries.
This CD-R was burned from WAVes, spectrograms look properly.
That would be my biggest concern.  The disc is defective or damaged.
Probably not "properly"... I don't think you want  an "exact-perfect" copy of this bad disc...  ;)
I'm not quite understanding what's going on but when you rip one track at a time, are you getting all of the music, with gaps in the wrong places, or is some of the sound missing or corrupted?
If all of the "sound" is there, you should be able to "re-assemble" the tracks in Audacity with whatever gaps and/or leading/trailing silence you desire.
Or if you can't get it ripped digitally, does the CD play OK?   If it plays, you can make an analog recording (actually digital-to-analog-to-digital), or you can make analog recordings of the tracks you're having trouble with.
How old is the CDr?  Data on CDrs degrade over time and they can become unusable.
At about 10 years, most CDrs are nothing more than coasters.
JXL
