Topic: Applying ReplayGain to Wav Files (Read 3941 times) previous topic - next topic
I'd like to apply ReplayGain to a set of wav files before burning them to CD. Speek's Frontend is no longer supported and it doesn't work on my PC, so I need an alternative.
Any suggestions?
Any suggestions?
replaygain adds tags (which WAV doesn't support). convert to a lossless format, apply RG, then burn (within foobar)
You can apply WaveGain by itself and use whatever burning application you desire.
Actually, the mentioned Speek's frontend uses WaveGain. Obviously Grey is seeking for an easier solution than the command line program.
Omni Encoder will work.
One can also use WaveGain via an SFX program that will automatically run a batch file after extraction, then remove the extracted files once finished. I know it can be done via WinZip Self-Extractor and WinRAR.
Thanks for the tips. Unless I can find another option, I think I'll give Burrn a try.
