Topic: Clipping detection based on RG values? (Read 3258 times) previous topic - next topic
I wanted to indicate in foobar, if track with "RG track gain" applied to it would clip:
$ifgreater(
$add(
$muldiv($num($left($replace(%replaygain_track_peak%,.,),5),),89,100),
$num($replace(%replaygain_track_gain%,.,),)),
8899,Yes,No)
which basically means PEAK * 89 + GAIN (and multiplied by 100), but the result is incorrect: it doesn't shows correctly if the track is clipping
What's wrong here?
Assuming clipping prevention and limiting etc are disabled, then for a given replaygain_track_gain and preamp_setting (fb2k preferences), the track will be scaled by
scale = 10^((replaygain_track_gain+preamp_setting)/20)
new_peak = replaygain_track_peak*scale
Does this help?
David.
Yes, it helped. It cleared two things:
1. how to calculate clipping based on RG (I searched HA a lot and didn't find this)
2. it can't be made with foobar TF, as it doesn't support such math
thanks
With reasonable accuracy David's clipping eq. can be approximated with simple 2-nd order polynomial over custom range:
10^(x/20) ~ 0.01*x^2 + 0.12*x +1
[a href="http://img682.imageshack.us/img682/9071/89234612.png" target="_blank"]
