Topic: New VST adapter for foobar2000 (Read 35547 times) previous topic - next topic
Re: New VST adapter for foobar2000
Reply #150
Exactly the same situation @misio
I'm using iZotope Insight2.
Reply #151
foobar2000 is an audio player, not a DAW. It's highly unlikely that the internal architecture optimized for fast and efficient audio playback will be broken and changed to make VST plugins able to update their UIs in realtime. The VST support was added for audio effect supports, not for eye candy.
Reply #152
Yeah (I think anyone should understand that foobar2000 is not a DAW even though you can use DSPs within converter), but there is "Visualize with VST" that allows you to visualize audio with VST audio analysis plugins with minimal latency (but obviously it would not change audio output at all), which I use with AnSpec analog-style spectrum analyzer VST
Reply #153
Does this VST dsp work with more than stereo?
Should work. Do you know any specific VSTs that fail?
I tested  two upmix VSTs and while the gui of the VSTs shows that they work only the left and right channel is in the output.
Hello,
Same here. No signal from rear, center and LFE channels of (at least one) 5.1 upmix VST with no error reported. Upmix VST was working fine with old VST component. (Foobar 1.6.16 and VST component 0.11.7). Thanks for your work BTW.
Cheers.
I gave it a try again but the problem is still the same.  With stereo input there is only stereo output.
