Topic: Spider Monkey Panel (foo_spider_monkey_panel) (Read 361588 times) previous topic - next topic
Re: Spider Monkey Panel (foo_spider_monkey_panel)
Reply #1400
Uhm... disclaimer, have not really much experience with all this.
First, your scripts don't seem to work on win. Since it looks for py instead of python.
https://stackoverflow.com/questions/64697211/how-to-fix-py-is-not-recognized-as-an-internal-or-external-command-operable-p
Using doskey doesn't work for the lines using "subprocess.check_call()", so I had to edit the *.py files to use 'python' instead of 'py'.
Then V2 has different submodules than V1, it is not just a matter of using the scripts from V2 on V1. i.e. it now complains that there is no lexilla submodule too.
EDIT: as far as I understand, do you mean not only the scripts must be ported to V1, but also submodules and then all this?
https://github.com/TheQwertiest/foo_spider_monkey_panel/commit/c9d8d83d577516153070047572fa78d69e976906
There is now way to simply build v1 as is?
Reply #1401
I develop SMP (and all other fb2k components) exclusively on windows =)
"py" is an utility that comes with default windows Python installation (https://stackoverflow.com/a/50896577)
But I've never said that only scripts changes are needed, on the contrary, I've mentioned scintilla submodule (which lexilla was part of at some point).
Anyway, my previous reply was not intended as a guide, but rather a pointer on where one can look for the changes required to make v1 buildable.
Reply #1402
Anyway, my previous reply was not a guide, but rather a pointer on where one can look for the changes required to make v1 buildable.
Well all my installations of python only had "python.exe" not py. And all references of py I found were related to unix systems, my bad anyway.
Understood. I thought v1 was buildable without further changes at some point of the commit history. Thanks anyway
Reply #1403
IIRC, the problem is with environment and not SMP code per se: older scintilla is not buildable with newer Python version, so either the newer scintilla version or older python version is required.
There are also might be some compilation errors caused by newer VS, but I don't remember any specifics.
Reply #1404
Could someone help me create a "mood" button akin to what's present in Br3tt's smooth playlist browser? On click to write anything to specific tag and on second click if this tag is present - remove it.
Reply #1405
Does pseudo transparency work in SMP? It never seems to work for me. For example, I can make ESLyrics display the lyrics over top of DarkOne's artwork script, but it doesn't refresh properly and the lyrics are showing a strange 'double image' effect. There's no difference when having SMP's pseudo transparency checked or not.
Now if I do the same thing using a Panel Stack Splitter, ESLyrics and the DarkOne artwork script combo works fine.
Reply #1407
The problem is ESLyrics needs constant refreshing and I don't know how to do that in SMP. (I can do a one time refresh no problem)
I can do constant refreshing in PSS, however the coordinates have to be in per second and I get a slight flicker every second.
Reply #1408
This refreshes once per second but only if fb2k is playing.
function on_playback_time() }
    window.Repaint();
Use setInterval if you need it all the time even when playback is stopped.
https://theqwertiest.github.io/foo_spider_monkey_panel/assets/generated_files/docs/html/global.html#setInterval
