Topic: foobar2000 does not always honor the global hotkey (Read 129 times) previous topic - next topic
I have set a global hotkey, but it does not always work. If I have O&O ShutUp10 open, foobar2000 won't react to the keypress.
This also happen when I use DVD Shrink, global hotkey does not work. Even if I close DVD Shrink, global hotkey does not work.
This applies to foobar2000 v1.6.6 and foobar2000 v1.6.7b5
Using win10 x64 20H2 (19042.1023)
Core (2021-05-17 14:20:42 UTC)
    foobar2000 core 1.6.6
foo_albumlist.dll (2021-05-17 14:19:58 UTC)
    Album List 1.6.6
foo_audioscrobbler.dll (2016-08-23 18:35:02 UTC)
    Audioscrobbler 1.4.7
foo_bitcompare.dll (2021-03-04 15:26:38 UTC)
    Binary Comparator 2.2
foo_cdda.dll (2021-05-17 14:20:02 UTC)
    CD Audio Decoder 1.6.6
foo_converter.dll (2021-05-17 14:20:00 UTC)
    Converter 1.6.6
foo_cuefixer.dll (2020-10-19 23:52:44 UTC)
    CUE fixer 1.24
foo_dsp_crossmix.dll (2019-09-01 16:13:36 UTC)
    Crossmix DSP 0.1
foo_dsp_delta.dll (2008-10-24 15:57:16 UTC)
    Noise Sharpening DSP 1.0.0
foo_dsp_eq.dll (2021-05-17 14:19:58 UTC)
    Equalizer 1.2.2
foo_dsp_nogaps.dll (2019-12-20 20:19:42 UTC)
    Gap Killer DSP 0.4.2
foo_dsp_resampler.dll (2019-12-09 18:08:29 UTC)
    SoX Resampler 0.8.7
foo_dsp_skip_silence.dll (2019-12-20 20:31:31 UTC)
    Skip Silence 1.0.3
foo_dsp_std.dll (2021-05-17 14:19:58 UTC)
    Standard DSP Array 1.6.6
foo_dsp_utility.dll (2021-01-12 10:45:50 UTC)
    Utility DSP Array 1.2.3
foo_dsp_vlevel20080302.0.dll (2018-06-27 12:29:49 UTC)
    VLevel 20080302.0
foo_fileops.dll (2021-05-17 14:20:02 UTC)
    File Operations 1.6.6
foo_freedb2.dll (2021-05-17 14:20:00 UTC)
    Online Tagger 0.8
foo_hdcd.dll (2018-04-12 18:27:39 UTC)
    HDCD decoder 1.19
foo_input_reverse.dll (2018-01-09 12:16:38 UTC)
    Reverse Player 1.0
foo_input_std.dll (2021-05-17 14:20:16 UTC)
    FFmpeg Decoders 4.3.1
    Standard Input Array 1.6.6
foo_jesus.dll (2018-08-15 21:39:27 UTC)
    Autosave & Autobackup 10
foo_out_wasapi.dll (2020-12-30 12:08:46 UTC)
    WASAPI output support 3.4
foo_playcount.dll (2020-07-01 22:00:50 UTC)
    Playback Statistics 3.0.4
foo_r128norm.dll (2017-02-05 10:43:31 UTC)
    EBU R128 Normalizer 1.12
foo_rgscan.dll (2021-05-17 14:20:02 UTC)
    ReplayGain Scanner 1.6.6
foo_sanitizer.dll (2021-02-15 13:49:24 UTC)
    Tag Sanitizer 1.3
foo_skip.dll (2021-03-21 07:25:50 UTC)
    Skip Track 1.33
foo_ui_std.dll (2021-05-17 14:20:12 UTC)
    Default User Interface 1.6.6
foo_uie_lyrics3.dll (2016-03-18 14:04:24 UTC)
    Lyric Show Panel 3 0.5
foo_verifier.dll (2020-07-02 11:34:34 UTC)
    File Integrity Verifier 1.4
foo_wave_minibar_mod.dll (2021-05-09 14:15:18 UTC)
    Waveform Minibar (mod) 1.0.45
Re: foobar2000 does not always honor the global hotkey
And this sounds like an OS bug, since foobar is using the exact correct way to listen for hotkeys globally: By registering the exact key combinations with Windows and getting notified when they're pressed.
Really, there is no other way to do it that doesn't involve writing the equivalent of a global key logger. And then you contend with random software either thinking your application is malware, or games thinking that your software is a cheating utility.
