Topic: Spider Monkey Panel (foo_spider_monkey_panel) (Read 129895 times) previous topic - next topic
Re: Spider Monkey Panel (foo_spider_monkey_panel)
Reply #1000
Back by unpopular demand is my ye olde sox spectrogram seekbar from the WSH panel mod days.
You'll need sox and ffmpeg extracted to a folder named sox inside your profile folder (or edit the paths in the script)
Limitations:
since the script passes the filename to ffmpeg for decoding, your input components are irrelevant
it only works on local files with a known length
cue sheets/files with chapters are not supported
Reply #1001
I forgot to mention that FontAwesome is required.
https://github.com/FortAwesome/Font-Awesome/blob/fa-4/fonts/fontawesome-webfont.ttf?raw=true
I also forgot to make it clear the image when playback stops. I've attached a fixed version.
Reply #1003
@TT @wcs13 @MordredKLB I've made some changes that should fix the `freeze on exit` issue (once dev build is finished building).
@MordredKLB Note that this build includes the rollback of timer changes.
Reply #1004
Thank you, my theme is still using the stable v.1.4.1. Will try it out!
Reply #1005
Limitations:
Do you mind if I add it to complete samples in smp_2003 repo?
Reply #1007
Go for it. It's not like there have been restrictions on anything I've posted before. It's horrible code though!
BTW, I noticed that when using utils.ColourPicker, you don't pass the default_colour on to uChooseColor internally. It should do this so the user can actually edit the default colour instead of starting with black every time. My original always did this.
https://github.com/marc2k3/foo_jscript_panel/blob/a96ffd1625caa1b1aa825fc0dd66ff52072a654b/src/ScriptInterface/Utils.cpp#L50L51
Reply #1008
Thanks for the spectrogram seekbar script @snotlicker . That WSH panel script for spectrogram seekbar was hard to find. Definitely it should be added together with the other SMP scripts
Reply #1009
There have been at least 2 reports of relative paths not working and crashing even if the files are there with latest dev release and previous ones.
https://hydrogenaud.io/index.php?topic=120979.msg1000890#msg1000890
https://hydrogenaud.io/index.php?topic=121277.msg1000545#msg1000545
The same files work fine on different systems on my side.
Reply #1010
Another report about relative paths not working, crashing ( windows 10, foobar 1.6.6, SMP 1.5.1 and the latest dev released)
Error: Spider Monkey Panel v1.5.2-dev+327ba5dc ({311F3B08-764E-4315-8AB1-BF3F99B97668})
include failed:
Path does not point to a valid file: helpers\buttons_xxx.js
File: <main>
Line: 35, Column: 2
Stack trace:
  @:35:2
Error: Spider Monkey Panel v1.5.1 (Playlist Manager: Playlist Manager v0.2 by XXX)
include failed:
Path does not point to a valid file: helpers\helpers_xxx.js
File: <main>
Line: 27, Column: 1
Stack trace:
  @:27:1
Error: Spider Monkey Panel v1.5.2-dev+327ba5dc (Playlist Manager: Playlist Manager v0.2 by XXX)
include failed:
File: <main>
Line: 27, Column: 1
Stack trace:
  @:27:1
Another problem, although I don't know if I should post here or to WiLB's page (it seems that only Library Tree, Biography, Find & Play scripts were affected, every time, other SMP scripts are ok)  After every unexpected shutdown caused by the interruption of electricity I have to reinstall those scripts, packages are corrupted, the settings are lost. Luckily I had those settings saved somewhere. This didn't happen before
Reply #1011
And another one
https://hydrogenaud.io/index.php?topic=120979.msg1000966#msg1000966
Reply #1012
If there is a folder with a Russian name on the way, then the panel crashes.
Reply #1015
@regor @kutuzof I've made some changes that should fix your issue with script paths (once dev build is finished building).
Reply #1016
Regarding issues with packages when unexpected shutdowns occur, e.g. through power failures. I have also reproduced the corruption of package.json that occurs in this scenario. Does package.json have to be saved on foobar2000 shutdown, since package.json seems to get saved when changes are made on the package tab anyway? Or can some other fix be implemented?
