Topic: External Tags (Read 36685 times) previous topic - next topic
Re: External Tags
Reply #325
@moonra it should. Do a test to make sure: make a copy of one of the files, create the external tags file for it, edit some tags and do a replaygain scan maybe, then check with a hashing tool if the copy and original still have the same hash. More info on the wiki: https://wiki.hydrogenaud.io/index.php?title=Foobar2000:Components/External_Tags_(foo_external_tags)#Usage
 You could also just set the files to be readonly through your file browser, then you can experiment all you want with peace of mind instead of a hashing tool.
Re: External Tags
Reply #326
Yes, you can, make sure to config the external tags (writer) to be in the first list of priority in Playback>decoding preferences.
Or, in the context menu >tagging>edit (or) create external tags.
11 years latter.... i finally created an account.
Re: External Tags
Reply #327
I tried to use the subj, creates a file in the target folder that does not run foobar2000, also creates it in ansi encoding, which makes it impossible to save Unicode characters, what are the advantages over m-tags???
Re: External Tags
Reply #328
I can put unicode characters like 😀 into my ext tags just fine, and they even show correctly when I open the .tag file in my text editor (which you normally never need to do, mind you) with utf8 decoding.
Re: External Tags
Reply #329
The tags are in UTF-8 format and very much support unicode. The advantage over m-tags is that tagging is handled transparently - the tags are usable in the player automatically without doing any extra work. You don't need to modify files manually or replace files in playlists with custom tag versions.
Re: External Tags
Reply #330
Can the plugin emit external tags into files copied with "File Operations \ Copy to"? To clarify, I use External Tags to preserve original file integrity - mostly MP3 - intact and this works great on a PC. When I copy albums to a phone, file integrity becomes irrelevant but I still want to have proper tags because some files originally have none or very low quality metadata, so I'd like to re-use metadata kept in the SQLite instance. Version "1.0.20" release notes mention "external tag copying from the source file to the copy when using File Operations (only used for folder and APE tags)", does foobar2000 Android support "folder tags"? There also was some talk about it on page 9. Did I miss a setting somewhere?
On a side note, the SQLite instance seems to use file paths as keys. Given my files never change, is there a way to change the indexing to be more portable, like file checksum? Path indexes mean the tags are not preserved after the file was moved to a different dir, which is annoying.
Re: External Tags
Reply #331
Hello to the developer.
1. For some reason, I don't have a reader.
2. I really want to be able to edit the TAGS file using an external editor, for example, a text editor, how can this be implemented? How do I open a file to manually correct the tags? Including redcasting the cover
3. I can't set the file name using the usual syntax, for example %album artist%
4. Causes confusion identical windows with native ones
In the end, I would like a substitute for CUE with advanced features
5. I also want to understand that the topic header says "experimental" - hence the question - it makes sense to reformat your entire discography using your add-on, and what if you stop supporting it and the new version of the player is not compatible?
6. Also interested in the question of writing back to the tags of files CUT INTO SEPARATE tracks
Re: External Tags
Reply #332
Not the developer, but...
1) as mentioned in the wiki this is normal on newer foobar versions.
2) the tags files are binary APE tags. You can edit them with text editors geared towards developers, but it's just not recommended to do so because it's easy to get some required binary characters wrong. You should edit tags through foobar. Once a file has exttags, the tags shown by foobar in the standard tags dialog you're familiar with (and all other tagging components) will be the exttags.
3) File Operations -> rename/move works perfectly for me, moving/renaming the files along with any tag files they may have, and foobar interprets filename variables in them. The operation preview won't list the tag files though, you just have to trust the component. What are you doing exactly that doesn't seem to work?
4) the point of exttags is that it stores tags differently but otherwise has identical behavior/handling to standard tags. It's totally transparent. Why do you want to have a visible difference between standard and ext tags?
If you want something that's more like cue files, perhaps m-tags is closer to what you want. Its metadata files are recognized as separate files from the audio they reference, basically a playlist with metadata.
Re: External Tags
Reply #333
1. What does absence affect?
2. A binary editor .... hmmmm .. this is understandable, they can edit whatever you want, but))) I wanted to edit in a visual editor
3.
4. For example, I want to double-click a cue file in the player, how to do it and quickly edit it as it does. Double-clicking from the explorer folder does not start playback, writes a syntax error (((
5. You understood me correctly, m-tags is suitable for these purposes, but it is not supported by the developer and messages hang for 2 years ... for example, I am maddened by the impossibility of saving to a folder with files, I have to constantly go through the whole path in the explorer - this is very inconvenient and other minor difficulties
Re: External Tags
Reply #334
External tag data gets copied to the copy automatically.
External Tags only work in the Windows version with the component installed. Apply the tag data to the files for portable use.
SQLite is not meant to be portable, the other two options write the tags data to the file location and they are portable by nature. Using path is the only 100% exact method to identify correct file and it's also the fastest identification method. If you use foobar2000 to copy or move the files the database is automatically updated.
Re: External Tags
Reply #335
Titleformatting is not interpreted here. You should stick to the default name unless you have very good reason to use something else.
The whole point of folder tags is to contain all the tags of a directory in a single, easy to manage file.
The rest of your questions were nicely answered by Marnes. Frankly I don't really understand your Cue related questions. My suggestion would be to avoid anything cue sheet related unless you are actually burning an audio CD and need cues.
Re: External Tags
Reply #336
I went and checked again, the files are copied with original tags. There are new entries in the SQLite for copy target paths, was this what you meant? If yes, then that does not help with my use case at all, I'd like for copied files to have tags from the DB, to bake the tags in for portability.
This works indeed, thank you 👍
Re: External Tags
Reply #337
@Case The external tag file in my opinion should have a unique name for example
Metallica - 1999 - S&M (Live).tags
What does the absence of a reader affect?
And of course you want to be able to make adjustments to the tags file using an external editor...
Re: External Tags
Reply #338
also, in my opinion, the automatic creation of a tag file should be disabled, if the folder contains a track album, I am more satisfied when the tags are written to the flac file, but in the image, when there is a cue, the creation of a tag file is justified
A very big request, work with the context menu-combine all the items in one drop-down subordinate list, otherwise everything is scattered and you can not distinguish the commands of the player from the commands of the application, it is also inconvenient to work with shift, that is, with hidden items
Re: External Tags
Reply #339
For a bit of clarification, I would like to apply replaygain to my entire music library. The near total majority of it is in FLAC or MP3. The issue is I cannot afford to modify a single bit of any of those files. Having the replay gain tags stored externally is absolutely perfect, is this component something that can enable that? I've tested this  a tiny bit by setting my files to read only, then scanning with replaygain, which appears to work and apply the tags, then verifying the files and they haven't been altered. But I'd just like to know before I pull the trigger on the many hours needed to scan the whole lot :)
Re: External Tags
Reply #340
That should work perfectly with this component, @coldblood.
Re: External Tags
Reply #341
Awesome thanks Case.
