Topic: Using Exact Audio Copy V 1.8 to create a WavPack and an MP3 file (Read 446 times) previous topic - next topic
Hi Everyone,
I used to use EACH 0.95 but things have changed.
The latest version of EAC is V1.8 and all the settings and arguments have changed.
To start I tried to create a FLAC file using the default settings that came with EAC.
Path of Compressor
C:\Program Files (x86)\Exact Audio Copy\FLAC\FLAC.EXE
Additional Command Line Options:
-6 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "BAND=%albuminterpret%" -T "ALBUMARTIST=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" %hascover%--picture="%coverfile%"%hascover% %source% -o %dest%
When I ran "Copy Image and create cue sheet"  I got an error that said
"External Compressor Returned an error!
Options: -6 -V -T "ARTIST=AAAA -T "TITLE=BBBB -T "ALBUM=CCCC -T "DATE=YYYY -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "BAND=%albuminterpret%" -T "ALBUMARTIST=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" %hascover%--picture="%coverfile%"%hascover% %source% -o %dest%
File: C:\Program Files (x86)\Exact Audio Copy\AAAA - CCCC.wav
I have substituted AAAA, BBBB, CCCC, YYYY etc. for the names of the Artist, Song Title, Album, Year, etc.
Before running "Copy Image and create cue sheet", I had unchecked "Delete WAV file after compression" just to see if a wav file is created but I could not find a WAV file either.
I am obviously doing something basic wrong. Does anyone have a clue?
Re: Using Exact Audio Copy V 1.8 to create a WavPack and an MP3 file
Substituting is going to make it difficult to see what's going on.
The default Additional Command Line Options should only be an issue if there were characters the encoder didn't like but your files shouldn't output to here
but you may have substituted the path too.
Where did you tell EAC to output the image file?
korth
Your files shouldn't output to here
This is the error I got.  I was only testing EAC so the the files output to the C:\Program Files (x86)\Exact Audio Copy\ folder. Eventually, after I get it working I would choose a different folder.
https://prnt.sc/68FbU-JAHINb
When I start the Copy Image and Create Cue Sheet option I can see EAC working and creating a WAV file
https://prnt.sc/Vpy_xXwHNpdA
Then instead of creating FLAC files from the WAV file, it says Copy Complete
https://prnt.sc/g5zQUOJIA74m
Does this help?
I changed the directory to D:\TEST and deselected the Use External Compression option and it created 14 individual WAV files. Then I selected the External Compression option and it created a WAV file, CUE file, and a single FLAC file. See the WAV, CUE, and FLAC files below.
https://prnt.sc/YSxDz1hYugvG
You shouldn't try to extract to locations that require elevated permissions e.g. C:\ or C:\Program Files (x86)\
I see you worked that out.
Your files are likely in %localappdata%\virtualstore\  (C:\Users\yourusername\AppData\Local\VirtualStore\)
or more specific %localappdata%\virtualstore\Program Files (x86)\Exact Audio Copy\
because EAC didn't have permission to write to C:\Program Files (x86)\Exact Audio Copy\
The encoder was pointed to C:\Program Files (x86)\Exact Audio Copy\ so it failed to find the wav file.
edit spelling if > it
korth
