Topic: Resampler plugin (Read 499229 times) previous topic - next topic
Re: Resampler plugin
Reply #600
Speed comparison. The source file is a CD image, stereo, 16 bps, 44100 Hz. Duration reported by foobar2000: 55:41.150 (147 344 700 samples).
Conversion run untimed first so the source file gets cached in memory. C: is a fast NVMe SSD too, so not a bottleneck.
$ del C:\temp\out.wav & timer64 ffmpeg -i c:\temp\image.wav -af "ardftsrc=48000,atrim=start=0" -acodec pcm_f32le c:\temp\out.wav
- timed conversion ran three times, fastest run took 2.027 seconds. Average 2.065 s
- the conversion speed for the fastest run is 1648x realtime
$ del C:\temp\out.wav & timer64 ffmpeg7 -i c:\temp\image.wav -af "aresample=48000:resampler=soxr" -acodec pcm_f32le c:\temp\out.wav
- timed conversion ran three times, fastest run took 1.711 seconds. Average 1.711 s
- the conversion speed for the fastest run is 1953x realtime
The ardftsrc produced output length is still incorrect: 55:41.153 (160 375 360 samples)
Sox length is correct: 55:41.150 (160 375 184 samples)
147 344 700 / 44100 * 48000 = 160 375 183,67..., which rounds up to 160 375 184
Quality comparison:
$ ffmpeg -i swept_float.wv -af "ardftsrc=48000,atrim=start=0" -acodec pcm_f32le ardftsrc.wav
$ ffmpeg7 -i swept_float.wv -af "aresample=48000:resampler=soxr" -acodec pcm_f32le soxr.wav
$ ffmpeg7 -i swept_float.wv -lavfi showspectrumpic=s=1280x800 swept_float.png
ardftsrc.png:
X
soxr.png:
X
swept_float.png:
X
Edit: Added labels for images.
Reply #601
you are free to increase quality parameter to 2x or 4x of original default value if you want more than 16bit (> 92dB) output quality.
visual transforms are not good way to represent how resampler is cutting high end of spectrum too much.
For example better to take up-sampling than down-sampling to original sample rate and compare output differences between resamplers and not by using visuals but comparing output with SDR (signal-to-distortion ratio) or similar measurements.
ardftsrc give superior quality compared to soxr resampler (when comparing with same quality parameters) at same or faster speed at lower latency and much lower complexity of code. (And ardftsrc code is not 100% hand optimized like soxr resampler)
The only real difference is in higher spectrum which is anyway not that relevant for ordinary listeners.
Reply #602
Since lvqcl still hasn't released a 64-bit version I wanted to see if I can improve the quick conversion I did earlier.
Here's a new build that supports both 32-bit and 64-bit foobar2000 versions, dark mode is supported and now fast mode works also on 64-bit variant.
I also added options to resample only chosen samplerates or to resample everything else but the chosen samplerates, so it should allow doing everything mod and mod2 versions did in one file. I didn't see sources for lvqcl's mod variants so this is my custom implementation.
Registered just to give my thanks for this, really appreciate it :)
