Lossless vs. Redbook tests?
Reply #36 – 2009-04-04 07:53:04
Axon, this is getting silly. If someone comes along wondering whether or not there are people who can breathe under water, do we need to rally everyone round to conduct a test to prove in a statistically valid way that all our members cannot breathe under water? The problem I had with the OP's original question is that a step was missing. a) OP reads something and is inquisitive (no problem) b) OP immediately looks for evidence / research to confirm or deny this. What's missing is the OP's experience. If the second step had been "well, can I hear a difference?" then the OP's question would have been what's the correct method for testing FLAC vs. WAV and everyone at HA would have said ABX with helpful links to foobar's ABX comparitor and a warm welcome to HA. I think the reason for the strong opinions on this is simply that people at HA are used to doing ABX tests and thus are fully aware of the futility of testing what is essentially WAV vs. WAV. I guarantee that if the OP was used to conducting blind ABX tests the OP wouldn't have asked the question. Likewise, the OP can't breathe under water and is presumably not active on the Atlantis Forum asking whether this ability in humans has been properly tested. So, I agree with you that all this theory is not the right way to go, but where I disagree is that the OP is the one that should be encouraged to engage in the practical: Do your own ABXing and start with WAV vs. LAME -V 0, and ask 2 questions: 1) Can I hear a difference? 2) Are the bits identical? The OP's likely answer is NO, NO. Then move to WAV vs. LossyWAV --standard, likely answer, NO, NO. Then the OP can decide whether or not he/she can be bothered to get to the one where the answer is NO, YES. In so doing they will have answered their own question as to why no one else thinks it's worth doing. Now I'm off to set up a poll to see how many HA members can breathe under water, and will probably come to the statistically valid conclusion that listening to LAME at -V 2 makes you less likely to breathe under water. C. [EDIT: Added some stuff about Atlantis]
