Topic: faad fails in PS Conformance test..? (Read 1999 times) previous topic - next topic
Hai all,
I have found the following thread.
http://www.hydrogenaudio.org/forums/lofive...php/t62640.html
There, it was mentioned that faad fails to successfully decode some of the ISO PS Conformance streams.
Is it still the case? If bug found, was it solved..?
I could not find a reason/solution for that. did menno or others replied for this issue..?
Regards,
Vasanth.
Prove the worth of being You.
