Topic: Question about Lepai Tripath Class-T Hi-Fi Audio Mini Amplifier (Read 3985 times) previous topic - next topic
I have a 2 bookshelf speaker (50 watts 08 omhs each speaker) laying around the house unused. Just wondering if i can use  Lepai Tripath Class-T Hi-Fi Audio Mini Amplifier with that bookshelf speakers spec? I mainly want to use the amp for my desktop pc.
Lepai-Tripath-Class-T-Amplifier
http://www.amazon.com/Lepai-Tripath-Class-...cm_cr_pr_sims_t
Yes it will work.
The most serious problem with most switchmode power amps is that their frequency response depends on the speakers they are hooked to. Not a horrible problem, but one that is potentially slightly audible.
How so? I've never heard of that, care to explain, or give a link with explanation?
Error 404; signature server not available.
It's a problem common to most switchmode amps - there is a low pass filter on their output that has increasing reactance even within the audio band. The filter is outside any feedback loop.
Yes it will work.
Is this Lepai amp setup better than a desktop speakers and will it sound better.
