Topic: HDCD Decoder (Read 337552 times) previous topic - next topic
Re: HDCD Decoder
Reply #525
Hi, I have a couple of requests:
- Can you provide an option just to detect HDCD (and not decode)?
- Would it be possible for the decoder to at least detect HDCD in a raw LPCM input (so not contained in one of the supported file formats), such as provided by the foo_record plugin & the foo_upnp plugin's UPnP renderer when streaming L16?
Re: HDCD Decoder
Reply #527
Sorry, looks like you misunderstood me. I meant just auto detect HDCD, ie, where the HDCD status variable gets set (to 'yes') - I'm using the provided %__hdcd% field to flag HDCD presence in the current played audio (in fb2k's status bar).
Re: HDCD Decoder
Reply #529
Plain compile with x64. No alterations done.
That and they listed a patreon list. But "patreon.h" is now missing from their original repo.
Re: HDCD Decoder
Reply #530
Thank you very much!!!!!
Re: HDCD Decoder
Reply #531
Hello! I'm looking for foo_hdcd.dll v1.16. Maybe you can help me with it. I need only this version to test. I am now using v1.15 and it plays correctly all HDCDs.
From v1.17-v1.20 there is a bug when playing cue files in foobar if the HDCD disc have some tracks that are not encoded with HDCD.
Please check this HDCD Sampler Volume 2 (1995). This is the best test disc to check HDCD decoding and the difference in quality with or without HDCD technology. See the back side of CD for info.
X
Tracks 1-9 are HDCD.
Tracks 11, 13, 15 are HDCD, but they play incorrectly, without HDCD decoding.
Tracks 10, 12, 14 are not HDCD, but they starts to play incorrectly as HDCD, then switch off HDCD decoding after 5 seconds.
Scanner also detects this tracks 10-15 incorrectly
If i play the same tracks not from the beginning but in the middle of the track, it plays correctly.
If i split this cue file in to separate tracks, they play correctly.
If i use foo_hdcd.dll v1.15 this disc also play correctly and the Scanner shows correct info.
So the problem is only with foo_hdcd.dll v1.17-v1.20 when playing HDCD with cue playlist.
By the way, i found the same problem reported by another user:
https://hydrogenaud.io/index.php/topic,79427.msg1010098.html#msg1010098
MOD edit: Link removed TOS9
MOD edit 2: added referenced image of back
Re: HDCD Decoder
Reply #532
@mudlord
Could you possibly make this into a component file for easy install? not sure where to put this dll
EDIT:  just stuck in components folder but it would still be nice so its more  inline with others?
Re: HDCD Decoder
Reply #534
@mudlord
Would make sense to do a compile then for x86 while I'm at it and bundle the x64 component, I guess.
Re: HDCD Decoder
Reply #535
@mudlord
Mudlord, could you please compile foo_hdcd v1.15 for foobar2000 v2.0 x64?
Because it's the last usable version of all.
MOD edit: fix mention
Re: HDCD Decoder
Reply #536
kode54 yeeted all his stuff from orbit, so thats impossible.
Re: HDCD Decoder
Reply #538
Is there a simple way to let a HDCD tag control what is passed on to ffmpeg -af hdcd for playback?
Tag - no. But it is possible by using double extension like *.hdcd.flac and setting appropriate decoder priority for foo_input_ffmpeg over built-in FLAC decoder. Also disable_autoconvert=0 must be used to work with foo_input_ffmpeg: -af "hdcd=disable_autoconvert=0"
Re: HDCD Decoder
Reply #539
Could you be so kind to attach source code that you have for the last version foo_hdcd 1.20 ?
So that anyone else can fix the bugs in it.
