Topic: How to point .fpl to new drive address (Read 996 times) previous topic - next topic
Just replaced an old Win 10 32 bit with new Win 10 64 bit. My music library is now D: drive rather C: on the old machine. I can play from my library but the path for the playlists created on the old machine still show C: drive. How do I point the load playlist command to the D: address?
Thanks,
thelonius
Re: How to point .fpl to new drive address
Thanks for the prompt response. I downloaded the .dll and put in the C:\Program Files (X86)\Foobar2000 folder. Restarted fb2k but no revive menu entry under Edit or Preferences. When I load a playlist and play I get this for every track e.g. -
'Unable to open item for playback (Object not found):
"C:\Media\Music\CD Library\Jazz\Modern Jazz Quartet\A Celebration\Modern Jazz Quartet-Cherokee (Indian Love Song).mp3" '
What am I doing wrong? Would appreciate any help you can give. PS I am running v1.4.3, recently downloaded for the new machine.
thelonius
Install the component via the File/Preferences/Components page. Either by drag and dropping it to that window or by using the Install button. Then you should have the menu options mentioned in the linked forum post.
It worked! Thanks.
