Topic: foo_skip: skip tracks that match a specified search query (Read 345016 times) previous topic - next topic
Orion33, eurekagliese and 1 Guest are viewing this topic.
Re: foo_skip: skip tracks that match a specified search query
Reply #775
No, that's not at all what I'm saying. The query string in Preferences determines which tracks are skipped entirely. Skipping parts of tracks is based on tags in those files.
Tags are changed by opening properties of the track. Fields are the text labels on the left, like Artist, Title, Album... For partial skipping a track needs a field called Skip with timestamped data of parts that one wants to skip.
Reply #776
I'm not sure I fully follow your explanation.
So what I set already isn't enough to get each playing file jump in time?
Specific tags are needed?
Can you give a specific example how to achieve a jump in time in just one mp3 file?
What should I setup, where and how.
Reply #777
It's not enough. The string in preferences is checked for each track and if running the query against current track returns true value, the entire track is skipped.
Right click an MP3 file in foobar2000, click 'Properties', then click '+ add new'. Enter the partial skip information here and save the changes with 'OK'. Below is a screenshot showing what it will look like. Notice that I left the hours away from the timestamp, it's not necessary to type them if they aren't needed.
X
Reply #778
[attach type=image]30473[/attach]
Thanks so much for the detailed answer!
Unfortunately for me, if that's the case, it won't be much of a use.
I need every track playing to jump in time and as I have a considerable amount of them, tinkering with each one individually doesn't seem practical.
Maybe if I find an easy way to add or remove the skip tag from all of them at once, it might be an option.
Appreciate your help.
Reply #779
I kind of figured you were looking at a wrong component. You should try Preview.
Reply #780
Thanks but if that is playing first seconds of tracks, not exactly what I'm looking for.
Anyway, found out I can easily add and remove the SKIP tag in multiple tracks with MP3Tag, so that problem solved :)
Reply #781
@Sergey77 - new version released with the bookmarking fix. Also contains some other small changes, including behavior change for automatic DSP insertion that ApacheReal complained about.
Reply #782
Case, I tested it. In the new version, these components work fine for these items. Thank you!
Are you planning to add "Add Skip Track bookmark" to the right-click context menu? - other component commands are already there, it would be convenient.
Reply #783
The context menu feels like a wrong place for that action. Context menu is supposed to show valid actions that you can perform to any number of selected tracks regardless of current playback state. Bookmarking playback position is only related to the active playing track. The on/off toggle isn't in the context menu either.
Reply #784
We really need some kind of "skip to here" and "skip when here" in the context menu or main menu.
I'm trying to use masstagger plugin to create the SKIP tag on the selected file and use the %playback_time% variable as a way to do it one keypress skip tag creation at this current time; but that plugin can't read the %playback_time% variable and I end up with "SKIP=%playback_time%" tag. :(
Reply #785
Maybe this context menu option "Add Skip Track bookmark" would only be available when playing a track? Accordingly, the bookmark would be added only for the active playing track. If more than one track is selected, this option is not available.
Reply #786
Can we change the "Add Skip Track bookmark" behaviour so instead of making the playback jump to bookmark, it skips the track at the bookmark?
Reply #787
^ Considering elcosomalo's question, I would add to my suggestion above that the "Add Skip Track bookmark" option could be available in the context menu for an inactive track as well. When selecting it for an inactive track, the bookmark is set to "0:00.000". Tracks in a playlist with "0:00.000" could be skipped during playback.
Reply #788
Hi. I would like to use this plugin to spased repeated audio files for memorization. This requires a more complex formula than %rating% IS 1, but I've run into some difficulties. There is nothing in the manual except for the information that it supports sql syntax and a link to a page. However, that page states that sql query allows built-in functions starting with the $ sign. I tried writing a test expression $mod(%play_count,3) EQUAL 0, but it gives 0 all the time. I also tried using the foo_dynfil plugin, but its fields also output always 0.
Could you please extend the functionality of the formula parser or make a more advanced plugin based on the template of this simple one?
Reply #789
It's not SQL syntax, it's foobar's search query syntax. Correct way to write the query you tried to use is:
"$mod(%play_count%,3)" EQUAL 0
It has been said numerous times but I'll say again: you can test your query (if it doesn't use the component's built-in features) in foobar's library search dialog. You'll instantly get feedback if the syntax is right and will get a list of tracks that match the query.
Reply #790
When writing the post, I made a mistake and didn't put the second % sign. When I noticed this, the edit function was not available.
I wrote correctly in Foobar. It doesn't work.
I didn't know about the quotation marks. Thanks, that seems to be working now.
