Topic: Lyricsgrabber2 Feedback & Discussion (Read 167708 times) previous topic - next topic
Reply #250
It would load but not work it I removed the line about importing unescape.
Sorry about that.  I thought the unescape function came with the component.  Here's the code for that function:
http://codeviewer.org/view/code:5289
Save the code as unescape.py, and store it in your "C:\Users\Gonzo\AppData\Roaming\foobar2000\user-components\foo_lyricsgrabber2\pygrabber\system\" directory.
For future reference (in case the codeviewer link breaks), here's the unescape function:
import re, htmlentitydefs
# Removes HTML or XML character references and entities from a text string.
# @param text The HTML (or XML) source text.
# @return The plain text, as a Unicode string, if necessary.
def unescape(text):
    def fixup(m):
        text = m.group(0)
        if text[:2] == "&#":
            # character reference
            try:
                if text[:3] == "&#x":
                    return unichr(int(text[3:-1], 16))
                else:
                    return unichr(int(text[2:-1]))
            except ValueError:
                pass
        else:
            # named entity
            try:
                text = unichr(htmlentitydefs.name2codepoint[text[1:-1]])
            except KeyError:
                pass
        return text # leave as is
    return re.sub("&#?\w+;", fixup, text)
  Thanks very much.
I will try it very soon.  Leaving on a business trip this morning but I am eager to try it.
Reply #251
def unescape(text):
    def fixup(m):
        text = m.group(0)
            try:
                else:
            except ValueError:
                pass
        else:
            # named entity
            try:
            except KeyError:
                pass
That worked!  Of course when I tried to copy and paste the code I got an indent error but when I just downloaded the text it worked beautifully!  Gracias, phot0nic
Reply #252
While typing up this response, I just noticed that copying and pasting from a codebox on this forum doesn't seem to retain the indentations, which will break the script.  I've uploaded the script code here:
http://codeviewer.org/view/code:5143
Just use the dropdown in the upper-right to download the code with indentations intact.  Again, rename it to *.py and place it in the appropriate directory.
Could you please re-upload the code? The link is broken and I couldn't make it work with the indentation problem.
Reply #253
LyricWiki made a small change to their API and the script I posted before stopped working.  I fixed my script, and included the unescape function so that you don't need two files (klonuo's suggestion didn't work for me).  I have attached the updated script to this post:
http://www.hydrogenaud.io/forums/index.php?showtopic=110032
