Topic: AMIP - the complete now playing plug-in (Read 231164 times) previous topic - next topic
Reply #300
I'm having trouble with this plugin using the latest foobar with Live messenger 8.5.1302.1018 on Vista home.
The song title will display for a couple of seconds, then goes blank.
Reply #302
Please see:
http://amip.tools-for.net/board/index.php?...l=display+delay
I tried both solutions posted there and I'm still having a problem. Whenever I edit foobar configurations, I get a message saying "Unable to save config", and the Windows Media Player plugin was already disabled.
Reply #303
On Vista you must run AMIP Configurator as Administrator, otherwise it will not be able to save the file located in the Program Files directory.
Reply #304
I managed to edit the config now, but the only change is that it now takes slightly longer before the text shows up, then it's gone again.
Reply #305
Does it help if you use longer delay?
Put your plugin.ini to pastebin.ca and give a link.
Reply #307
Disable MSN 8 compatibility option and try longer delay.
What other non-default foobar plug-ins do you have?
Reply #308
Done, still nothing. I tried it at 5000, 7500, 9000 and 10000. I'm not running any other plugins.
Reply #309
OK, I'll try to reproduce the problem later.
Reply #310
Hi.
I was trying to configure the AMIP Dynamic Image Signature plugin so that on the forums i go i put the sig to show the music i'm playing, but i can't make it work, it should create a sig.png file or .jpg but i doesnt, maybe the problem is the web server i use that arent any good for it. But i would really appreciate if somehow that uses this could help me set it up correctly.
If you want to avoid fill the topic helping me send PM please.
Thank You.
Reply #311
This forum is for foobar specific AMIP problems. If you have AMIP only related questions, please use AMIP forum instead: http://amip.tools-for.net/board/ .
As for your issue, check the server logs, most likely some required components are not installed on your server.
Reply #312
Hi, I just updated AMIP to the newest version for Foobar and now my clipboard and MSN aren't working anymore.
I am on vista, use foobar 0.9.6 and Windows Live Messenger Version 2008 (build 8.5.1302.1018)
When I do clipboard thingy it now just shows the following: /me np: %1 - %2 (%4, %5)
I have the MSN Live Messenger (8.x) compatibility enabled. Though, without it doesn't show in MSN either.
Hope you can help me out with this one.
Thanks in advance.
Reply #313
Check that AMIP is installed/enabled. On Vista you may need to run installer and Configurator as Administrator.
Reply #314
i only use my pc as administrator and it is activated, so that's not it.
Reply #315
You can change the clipboard settings in the Configurator, you can also add MSN specific preset with different format for clipboard Settings, refer to the documentation. MSN Live Messenger (8.x) compatibility must be disabled, it's obsolete as stated in the documentation. In Messenger you must enable the "Show what I'm listening to" option in the status drop-down. I don't have 2008 version to test, but it works perfectly with 2009 version (14.0.8064.206). I'm using foobar 0.9.6.2, AMIP 2.65, Vista 64-bit.
Reply #316
Ok, I updated to foobar 0962.
No change.
No MSN and no Clipboard.
Before I upgraded AMIP all this was working.
I didn't change any setting.
And of course I use the Configurator.
Could it be that I am using Foobar as Portable version that it doesn't work (although it worked before with portable version)?
Here are the images of my configuration
Clipboard: http://orphax.com/andere/amip1.png
MSN: http://orphax.com/andere/AMIP2.png
Reply #317
Try reinstalling foobar with defaults.
Reply #318
Nope, nothing changed. Still the same.
when i give my shortcut still the outcome is /me np: %1 - %2 (%4, %5)
Reply #319
Or do you mean first uninstall and than install?
If so it will have to wait till tomorrow.
Have to back up my settings and such.
Reply #320
For some reason AMIP is not detecting the new songs in your foobar. Could be a conflict with some other plug-in or some settings.
Reply #321
i am going to do a rollback to previous version in that case
Thanks for the help anyhow. Will look into it later again though.
Reply #324
It opens for me but I get:
"tools-for.net expired on 07/03/2009 and is pending renewal or deletion."
