an
bool is_enabled();
method on the menu items would be useful to allow items to be turned on/off based on other state information in the player or component.
Can you add a separator programmatically from the menu_item interface?
ie. from
virtual const char * enum_item(int n)
Already implemented as the return value for get_display_data().
Sorry, I don't see how I use that to disable (MF_GRAYED style) one of my menu items.
For is_checked() I get a chance for each item in my menu instance to set or not set the check mark. I'd like the same thing for enabling or disabling the item.
Maybe you can override
virtual enabled_state get_enabled_state(int idx)
and return
MENU_DEFAULT_OFF when you don't want to display a specific menu item (but yes I know - that's not MF_GRAYED).
~ Florian
Maybe you can override virtual enabled_state get_enabled_state(int idx)
and return MENU_DEFAULT_OFF when you don't want to display a specific menu item (but yes I know - that's not MF_GRAYED).
~ Florian
Damn, I totally overlooked that as I was looking down in the derived object's interface.
So, the last question remains,
Is there a way to add separators in
return NULL;
