Topic: Converter: Copy other files (Read 1025 times) previous topic - next topic
In Converter Setup:
Copy other files: %album%.png
The pattern of %album% does not seem to resolve to anything.
Is this limited to only %filename% and %filename_ext% ?
Also, is there a "search" button somewhere to search all topics?
Thank you.
Re: Converter: Copy other files
The little question mark at the end of the input field shows instructions and tells it only supports those two fields you quoted. I actually didn't even remember it does any titleformatting as it's not really dealing with any tracks to parse titleformat info from. It's supposed to be extra per-directory operation once conversion is finished. Typical usage would be to use it with wildcards like *.png;*.log;*.txt.
Thank you for the quick response. It now makes sense that this command is performed "When done" so it no longer has access to the file tags.
Thanks again.
Sorry, one other question. When looking at the console log, it appears to log an error: "Copying: [invalid location]". Can this be ignored? I do not see any other errors and it reports success at the end. It is set to create multi-track files. This is the log:
Converting: "Redaction\01 Good Times.flac"
Destination: "Redaction\1974 - Phoebe Snow\Phoebe Snow.png"
Destination: "Redaction\1974 - Phoebe Snow\Phoebe Snow.flac"
CLI encoder: flac.exe
Destination file: Redaction\1974 - Phoebe Snow\Phoebe Snow.flac
Encoder stream format: 44100Hz / 2ch / 16bps
Command line: flac.exe --force --silent --verify --no-seektable --no-padding --padding=2097152 -4 - -o "Phoebe Snow.flac"
Working folder: Redaction\1974 - Phoebe Snow\
Copied OK
Converting: "Redaction\02 Harpo's Blues.flac"
Converting: "Redaction\03 Poetry Man.flac"
Encoder process still running, waiting...
Encoder process terminated cleanly.
Track converted successfully.
Thank you.
The useless "[invalid location]" log entry is removed in the latest foobar2000 v2.2 preview version.
Wow, thank you.
