Topic: JScript Panel (Read 294789 times) previous topic - next topic
Re: JScript Panel
Reply #1050
fb.RunMainMenuCommand
This is the main menu....
QSearch provides context menu commands. Not the same.
https://jscript-panel.github.io/docs/namespaces/fb/#fbruncontextcommandcommand
Thanks for your answer marc2k3.
I have used fb.RunContextCommand(command) and it works perfectly but only if the track is playing, which makes the option to create a button not so profitable.
buttons.update = function () {
var y = (Math.round((panel.h - bs) / 2)) + posi_horiz_bot;
this.buttons.lupa1 = new _button(panel.w - posi_vert_bot - (sep_bot * 2) - (bs * 2), y, bs, bs, { char : chars_cosi.lupa1, colour:colours.buttons }, null, function () { fb.RunContextCommand('QSearch/title HAS'); }, 'title HAS');
this.buttons.lupa2 = new _button(panel.w - posi_vert_bot - (sep_bot * 1) - (bs * 1), y, bs, bs, { char : chars_cosi.lupa2, colour:colours.buttons }, null, function () { fb.RunContextCommand('QSearch/album IS'); }, 'album IS');
If there is another better solution I would appreciate if you could tell me about it.
Re: JScript Panel
Reply #1051
I would recommend you to read the docs first...
X
https://jscript-panel.github.io/docs/interfaces/IMetadbHandleList/#runcontextcommandcommand
Replace
With this or something similar
if (plman.ActivePlaylist !== -1) {
var handleList = plman.GetPlaylistSelectedItems(plman.ActivePlaylist);
if (handleList && handleList.Count !== 0) {
handleList.RunContextCommand("'QSearch/title HAS");
Re: JScript Panel
Reply #1052
For QSearch to work, the handle list count must be 1. And since you have multiple buttons, it would be best to create a re-usable function like this...
function qsearch(what) {
// prefer playing file if playing or use selected playlist item if not
var handle = fb.IsPlaying ? fb.GetNowPlaying() : fb.GetFocusItem();
if (handle) {
fb.CreateHandleList(handle).RunContextCommand('QSearch/' + what);
	this.buttons.lupa1 = new _button(panel.w - posi_vert_bot - (sep_bot * 2) - (bs * 2), y, bs, bs, { char : chars_cosi.lupa1, colour:colours.buttons }, null, function () { qsearch('title HAS'); }, 'title HAS');
this.buttons.lupa2 = new _button(panel.w - posi_vert_bot - (sep_bot * 1) - (bs * 1), y, bs, bs, { char : chars_cosi.lupa2, colour:colours.buttons }, null, function () { qsearch('album IS'); }, 'album IS');
If you don't want that behaviour, you can prefer the selected playlist item at all times regardless of what is playing...
var handle = fb.GetFocusItem();
if (handle) {
Or if you want it to work on an item selected from a library viewer like album list you can use fb.GetSelection() like this
var handles = fb.GetSelection();
if (handles.Count == 1) {
handles.RunContextCommand('QSearch/' + what);
Note that the behaviour of fb.GetSelection is controlled by File>Preferences>Display>Selection viewers.
Re: JScript Panel
Reply #1053
3.0.17 for fb2k 1.6.6+
3.2.3 for fb2k 2.0 Beta 18+
The main landing page now contains version info/download links for both versions.
Re: JScript Panel
Reply #1055
3.2.5 for fb2k 2.0 Beta 18+
- Prevent component from loading on unsupported versions of foobar2000.
- Add plman.GetQueryItems.
- Add plman.GetGUID.
- Add plman.FindByGUID.
https://github.com/jscript-panel/release/releases
Beta 18 was stated as a minium requirement since 3.2.0 was released but wasn't enforced. Now it is.
Re: JScript Panel
Reply #1056
I want to thank regor (#1051) and marc2k3 (#1052) for their great help in creating my panel3 buttons
Re: JScript Panel
Reply #1057
Hoping to see an SMP update someday XD
The GUID thing would have made mi life much easier for the manager.
Now that I think of it, does it match the 'playlists-v1.4' index and names and also the 'playlists-v2.0' file names?
playlist-E1629559-B78C-45BE-A2C2-804141CC5E29
0B92BFBD7E2CEE9E2CCBDC69CBC910A7
I could try to hack it by reading files, instead of relying on SMP methods.
Re: JScript Panel
Reply #1058
Yes, the GUIDs match the content of the playlists-v2.0 folder. One minor difference is that my strings are wrapped in {}
console.log(plman.GetGUID(0)); // {88340458-489F-4B8C-AF30-040B6F82F424}
This is because the windows API for transforming strings back in to GUIDs expects them.
edit: I don't think hacks would work because playlist files are not generated in the playlists folder for empty playlists.
Re: JScript Panel
Reply #1059
Hi guys, I am trying to refresh my FB skin to newer versions (guess I'm a masochist) and my seekbar which I stole from DarkOne long time ago broke. So I switched to sample seekbar.
However it crashes when I switch tracks
JScript Panel v2.6.0-Beta.2 (Seekbar by marc2003)
JavaScript runtime error:
Invalid procedure call or argument
File: <main>
Line: 26, Col: 3
The code is
function on_paint(gr) {
gr.FillRoundRect(seekbar.x, seekbar.y, seekbar.w, seekbar.h, 6, 5, seekbar.c1);
if (fb.IsPlaying && fb.PlaybackLength > 0) {
gr.SetSmoothingMode(2);
gr.FillSolidRect(seekbar.x, seekbar.y, seekbar.pos(), seekbar.h, seekbar.c2);
gr.FillRoundRect(seekbar.x, seekbar.y, seekbar.pos(), seekbar.h, 6, 5, seekbar.c2);
FillRoundRect is what's crashing the seekbar, solidRect doesn't - why?
Re: JScript Panel
Reply #1061
You've set the arc_width to be 6px so the rectangle width needs to be at least double that. You're using seekbar.pos() for the width which can be less than 12px when a track starts.
Thank you very much!
Re: JScript Panel
Reply #1062
Advance warning for JSPlaylist users: The next version for fb2k 2.0 will have support for collapsable headers removed.
If you want to keep this functionality then you can can take these steps right now.
- Download this: https://jscript-panel.github.io/files/jsplaylist.zip
- Extract the jsplaylist folder to your foobar2000 profile folder
- Replace the contents of any JS Playlist instance with the contents of JS Playlist.txt
Any future component updates will not be able to touch these files!
Obviously this will be unsupported and will not receive any future updates.
Re: JScript Panel
Reply #1063
3.2.6 for fb2k 2.0 Beta 18+ https://github.com/jscript-panel/release/releases
- Minor IThemeManager bug fix.
- JS Playlist has had support for collapsable group headers removed. See the above post if you want to preserve this functionality by downloading a standalone copy.
- The playlist manager built in to JS Playlist and Smooth Playlist Manager now expose the foobar2000 context menu for playlist content.
- The Spectrogram Seekbar scripts can now generate images for tracks longer than 1 hour in length. This requires ffmpeg 6.0.
Re: JScript Panel
Reply #1064
3.0.18 for fb2k 1.6.6 - 1.6.16 https://github.com/marc2k3/fb2k-archive/releases/tag/latest
Re: JScript Panel
Reply #1065
 @marc2k3
For some reasons, after the update,  "plman.GetGUID(playlistIndex)" doesnt work anymore (maybe it's me).
I tried :
function getData() {
var data = [];
for (var i = 0; i < plman.PlaylistCount; i++) {
data.push({
value: plman.GetPlaylistItemCount(i),
for (var i = 0; i < data.length; i++) {
console.log(data[i].name);
and i have a crash  :
Erreur d’exécution JavaScript
(translated from french) :
the object doesnt manage the method "GetGUID"
Re: JScript Panel
Reply #1066
Looks like you've downloaded the wrong version meant for fb2k 1.6.x. It's not available there.
The docs are tagged with the minimum version required for certain methods/properties.
https://jscript-panel.github.io/docs/namespaces/plman/#plmangetguidplaylistindex
Re: JScript Panel
Reply #1067
what an idiot i am. Sorry.
Re: JScript Panel
Reply #1068
Hello,
can somebody please help me how I can configure my Jscript-component step by step if I want to see more than 4 images during a song played in Foobar? All the images are always in one folder called "covers".
An my folders look like this:
Music-A-Artist Name-Song Name (incl. the mp3-files)-covers
Music-B-Artist Name-Song Name (incl. the mp3-files)-covers
Music-C-Artist Name-Song Name (incl. the mp3-files)-covers.......
etc.
Sorry, tried it many times but it seems that I am really stupid.
Re: JScript Panel
Reply #1069
Using the Thumbs sample, you can right click and set a folder path to a folder. It will display all images contained within.
It's very hard to determine your intent from what you wrote but assuming covers is a subfolder where the playing/selected track is, this would work
$directory_path(%path%)\covers
Re: JScript Panel
Reply #1070
3.0.19 for fb2k 1.6.6 - 1.6.16
3.2.7 for fb2k 2.0 Beta18+
- Fixes a bug with the 3rd party Lexilla library used for keyword highlighting in the Configuration Window.
If, like me, you didn't notice - it's because lower case words were fine. Only words with uppercase chars like Date, JSON, Array, etc were affected.
Re: JScript Panel
Reply #1071
I have a script here that renders a Seekbar in the WSH Panel Mod. This script should be configured to work in JScript3 as well.
DT_TOP = 0x00000000;
DT_LEFT = 0x00000000;
DT_CENTER = 0x00000001;
DT_RIGHT = 0x00000002;
DT_VCENTER = 0x00000004;
DT_BOTTOM = 0x00000008;
DT_SINGLELINE = 0x00000020;
DT_NOPREFIX = 0x00000800;
var g_font = gdi.Font("arial",18,1);
var g_font_rating = gdi.Font("Arial Unicode MS",25,0);
var g_fileinfo = null;
var g_drag = 0;
var g_drag_seek = 0;
var ww, wh, area;
function RGB(r,g,b){
return (0xff000000|(r<<16)|(g<<8)|(b));
function RGBA(r,g,b,a){
return ((a<<24)|(r<<16)|(g<<8)|(b));
function Separator(x) {
this.left = x;
this.draw = function (gr) {
gr.FillGradRect(this.left-1,0, 1, wh-1, 90, RGB(133,133,133), RGB(0,0,0));
gr.FillGradRect(this.left,0, 1, wh-1, 90, RGB(163,163,163), RGB(163,163,163));
gr.FillGradRect(this.left+1,0, 1, wh-1, 90, RGB(60,59,59), RGB(0,0,0));
function separatorsDraw(gr) {
for (i in Separators) {
Separators[i].draw(gr);
function TimeFmt(t){
var zpad = function(n){
var str = n.toString();
return (str.length<2) ? "0"+str : str;
var h = Math.floor(t/3600); t-=h*3600;
var m = Math.floor(t/60); t-=m*60;
var s = Math.floor(t);
if(h>0) return h.toString()+":"+zpad(m)+":"+zpad(s);
return m.toString()+":"+zpad(s);
// --- APPLICATION START
function on_paint(gr){
var pos = 0;
var length = fb.PlaybackLength;
var txt;
if(length > 0){
if(g_drag){
pos = area * g_drag_seek;
txt = "Seek " + TimeFmt(g_drag_seek * length) + " / " + TimeFmt(length);
else{
pos = area * (fb.PlaybackTime / length);
var g_titlefmt = fb.TitleFormat("[%album artist% - ][%album% ]['['%date%']' - ]%title% >> $div($mul(100,%playback_time_seconds%),%length_seconds%) '%'");
txt = g_titlefmt.Eval();
gr.FillGradRect(4, 0, area, wh/2, 270, RGB(90, 90, 90), RGB(0, 0, 0));
gr.FillGradRect(4, wh/2, area, wh/2, 90, RGB(90, 90, 90), RGB(0, 0, 0));
gr.FillGradRect(0, 0, pos, wh/2, 270, RGB(0, 200, 200), RGB(0, 0, 0));
gr.FillGradRect(0,wh/2, pos, wh/2, 90, RGB(0, 200, 200), RGB(0, 0, 0));
gr.FillGradRect(2, 0, 1, wh-1, 90, RGB(163, 163, 163), RGB(163, 163, 163));
gr.FillGradRect(3, 0, 1, wh-1, 90, RGB(60, 59, 59), RGB(0, 0, 0));
separatorsDraw(gr);
gr.FillGradRect(ww-4, 0, 1, wh-1, 90, RGB(133, 133, 133), RGB(0, 0, 0));
gr.FillGradRect(ww-3, 0, 1, wh-1, 90, RGB(163, 163, 163), RGB(163, 163, 163));
gr.DrawRect(0, 0, ww, wh, 4.0, RGB(0,0,0));
gr.GdiDrawText(txt, g_font, RGB(255, 255, 255), 0, 0, ww, wh, DT_CENTER | DT_VCENTER | DT_SINGLELINE | DT_NOPREFIX);
var tfo_rating_a = fb.Titleformat("$if(%rating%,$repeat($char(9733),%rating%),)");
var tfo_rating_b = fb.Titleformat("$if(%rating%,$repeat($char(9734),$sub(5,%rating%)),)");
var txt_rating_a = tfo_rating_a.Eval();
var txt_rating_b = tfo_rating_b.Eval();
gr.GdiDrawText(txt_rating_a, g_font_rating, RGB(0,255,0), ww-120, 0, 110, wh, DT_LEFT | DT_VCENTER | DT_SINGLELINE);
gr.GdiDrawText(txt_rating_b, g_font_rating, RGB(255,0,0), ww-120, 0, 105, wh, DT_RIGHT | DT_VCENTER | DT_SINGLELINE);
function on_size(){
ww = window.Width;
wh = window.Height;
area = ww - 4;
Separators = {
one: new Separator((ww-4)/10),
two: new Separator((ww-4)/5),
three: new Separator(3*(ww-4)/10),
four: new Separator(2*(ww-4)/5),
five: new Separator(ww/2),
six: new Separator(3*(ww-4)/5),
seven: new Separator(7*(ww-4)/10),
eight: new Separator(4*(ww-4)/5),
nine: new Separator(9*(ww-4)/10)
function on_mouse_lbtn_down(x,y){
g_drag = 1;
if(g_drag){
g_drag = 0;
g_drag_seek = x / area;
g_drag_seek = (g_drag_seek<0) ? 0 : (g_drag_seek<1) ? g_drag_seek : 1;
fb.PlaybackTime = fb.PlaybackLength * g_drag_seek;
function on_mouse_move(x,y){
if(g_drag){
window.Repaint();
function on_playback_new_track(metadb){
window.Repaint();
function on_playback_stop(){
window.Repaint();
function on_playback_seek(time){
window.Repaint();
function on_playback_time(time){
window.Repaint();
// --- APPLICATION END
I can't do it with my basic scripting skills.
Maybe someone can help me here.
Thanks in advance.
Re: JScript Panel
Reply #1072
There's no point. WSH panel mod didn't suddenly stop working. The whole point of JScript Panel is that it supports bucket loads of new features that don't exist in other components. If you're not going to use those features, why bother?
Re: JScript Panel
Reply #1073
Ok, Thanks for the answer.
Actually I wanted to ban the WSH panel mod from my configuration. Because I have already implemented 2 other ads via JScript Panel, my Seekbar should also run over it. But I didn't get it.
Then it shouldn't be.
Re: JScript Panel
Reply #1074
I can live with that. I never liked that concept.
