Topic: Need feedback on a lossless audio codec which I'm writing. (Read 4748 times) previous topic - next topic
I am writing a lossless audio codec for my university's final year project. I need feedback so I can make necessary improvements. Please help me out.
You can find the source files and binary for windows on the link below
https://github.com/sahaRatul/sela
tested coder and decoder on windows. It seems you codec gives offset 1460 samples. So it is not perfectly lossless.
Hope you find that bug!
Solved : Decoder was actually decoding a 'ghost' frame that was not present in the encoded file.
Yeah, this is the output I got in the bit-compare in foobar2000:
Differences found in compared tracks.
Zero offset detected.
Comparing:
"C:\Users\xxxxxxxxxxxx\Desktop\bin\101 - Earth.wav"
"C:\Users\xxxxxxxxxxxx\Desktop\bin\101 - Earth_Sela.wav"
Length mismatch : 5:32.000000 vs 5:32.912426, 14641200 vs 14681438 samples.
Compared 14641200 samples, discarded last 40238 samples from the longer file.
Differences found within the compared range: 7 values, starting at 5:25.505034, peak: 0.0000305 at 5:25.505034, 1ch
Detected offset as 0 samples.
Is that what you fixed?
EDIT:  Yeah, there's some garbage hiss tacked on at the end of the encoded-decoded file.
Comparing:
Fixed that too, check the latest release on https://github.com/sahaRatul/sela/releases/tag/v0.1.1-alpha
