Topic: foo_run (Read 608474 times) previous topic - next topic
foo_run 0.3.7
Reply #250
you are welcome.
greets
foo_run 0.3.7
Reply #251
what would be the command line to open the NFO file thats in the folder the mp3 is in?
/music/artist-album/nowplaying.mp3
/music/artist-album/information.nfo
i want to open that information.nfo... so like a command to open *.nfo thats in the same folder as the mp3 thats playing....
Tnx
:EDIT: i now made this
"$lower($substr(%_path%,0,$strrchr(%_path%,'\'))00-%directoryname%.nfo)"
it will reflect the complete path of the folder and then make 00-foldername.nfo since most of my albums are tagged that way ... but i'd rather have it that it just looks opens any nfo file thats in the folder...
foo_run 0.3.7
Reply #252
@Light: did you try $directory_path(%path%)?
HTH.
Alessandro
foo_run 0.3.7
Reply #253
HTH.
Alessandro
yeah, that makes the code a bit simpler...
"$lower($directory_path(%path%)\00-%directoryname%.nfo)"
but still its not the ideal solution, since not all nfo's are tagged like that...
foo_run 0.3.7
Reply #254
Yep, apologies: didn't read carefully.
Not sure though: what do you open the NFO with? If the program you use supports wildcards at command line, it should work... otherwise I don't think you can do what you want using foobar2000 scripting language exclusively (but then again I'm not an expert ).
Alessandro
foo_run 0.3.7
Reply #255
HTH.
Alessandro
just try this to see if it works with notepad :
"C:\WINDOWS\notepad.exe" "$lower($directory_path(%path%)\00-%directoryname%.nfo)"
btw, try with replacing the program path that u want to use for .nfo files
foo_run 0.3.7
Reply #256
Pardon my ignorance but why is $lower needed? Windows file names are not case-sensitive right?
foo_run 0.3.7
Reply #257
Yeah, lower is not needed, its just to make it look more tidy, no function at all...
Well, the code works, cause if i do start => run => c:\mp3\mymp3folder\00-path etc, it opens the nfo in the standard nfo viewer (damn nfo viewer) so it works, but just on a couple of dirs cause not all nfo's are exactly in the same format... so i just want it to open the first nfo it can find in the directory.
Good thinking though, maybe the program opening it can find it, or maybe a bat file or something... I'll try later
EDIT
i got the solution:
make a batfile, called opennfo.bat and put it in c:\windows\ , put this in it: FOR %%A in (%1*.nfo) DO %%A
then in foo_run, use this command: opennfo.bat "$directory_path(%path%)\"
that simple actually....
foo_run 0.3.7
Reply #258
Hello,
I just want to play a radio stream (___.ogg.m3u).
I tried as path:
C:\Dokumente und Einstellungen\UIername\Eigene Dateien\Eigene Musik\tilos_high.ogg.m3u
but it didn´t work. It´s very simple I guess but I don´t know how. Thanks for you help and thanks to Florian for Mp3Tag and foo_run!!!
foo_run 0.3.7
Reply #259
Yes, simple. Put the path in quotation marks: "path"
foo_run 0.3.7
Reply #261
Just stumbled on this plugin the other day. Really great to have, i had to do a lot of trial and error with other codes to get it to work with some sites but it's a great plugin thanks.
foo_run 0.3.7
Reply #262
I'm on vista x64 and when using latest foobar version I can't get the following working:
"C:\Program Files (x86)\PROGRAMNAME"
If I place for example a program called albumart.exe in the following folder, C:\Program Files (x86)\foobar2000\utils\AlbumArt\. And I use the follwing string in foo_run, "C:\Program Files (x86)\foobar2000\utils\AlbumArt\AlbumArt.exe". It does not work. This happens with every progaram!
When I put the same file in de follwing folder, E:\AlbumArt\, and use the follwing string, "E:\AlbumArt\AlbumArt.exe". It works!
Am I doing something wrong? Or does this happen to others too?
foo_run 0.3.7
Reply #264
Try quoting the parentheses with single quotes:
"C:\Program Files '('x86')'\appfolder\app.exe" -pram
Thank you very much for the impressive quick reply! Quoting the parentheses did the trick.
foo_run 0.3.7
Reply #265
(Hi there... first time poster here)
Does anyone know how I could search http://www.songmeanings.net/ using foo_run?  I've been using the component successfully for a while now and I have buttons set to run seperate sites for various things (Wikipedia, last.fm, allmusic, etc.).  I did have this site set so that I could search both artist lyrics and song lyrics but suddenly I can't do it because they've changed their search method.  I think it is because it now uses "post" method instead of "get" for searches but I could be completely wrong.  I spent a while trying to work it out and the closest I could get was
http://www.songmeanings.net/search/?scope=artists&search_value=$replace(%artist%, ,+)&command=go
which comes up with some sort of error.
Would it be possible for someone to explain a quick and simple method of working out web searches for use in foo_run?
foo_run 0.3.7
Reply #266
Try this one:
http://www.songmeanings.net/search/1/?scope=artists&search_value=$replace(%artist%, ,+)&command=go
You can always use Google too:
http://www.google.com/search?q=$replace(%artist%, ,+)+$replace(%title%, ,+)+site:www.songmeanings.net
foo_run 0.3.7
Reply #267
The top one works great.  Thanks!
foo_run 0.3.7
Reply #268
This component does not work with the latest foobar beta, can you recompiled it, please, original author?
foo_run 0.3.7
Reply #269
Using the following without issue:
foobar 9.6 beta 2
foo_run 3.4
terry
foo_run 0.3.7
Reply #270
I'm running 0.9.6 beta 3 and foo run version 0.3.4 with no issues.
foo_run 0.3.7
Reply #271
Thanks both of you, I thought I was running the latest version.
foo_run 0.3.7
Reply #272
He's not working for me either
I've got Windows XP SP2
foo_run 0.3.7
Reply #273
It works for me after updating, please try updating http://mp3tag.de/en/fb2k.html . If it still doesn't work I think you have some other problems.
foo_run 0.3.7
Reply #274
it's still not working
i've got this message error
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01592DACh
Access violation, operation: read, address: 00000000h
Call path:
entry=>user_interface::init
Code bytes (01592DACh):
01592D6Ch:  C4 0C 85 C0 74 1A 6A 10 68 94 2E 5B 01 FF 75 14
01592D7Ch:  E8 34 8F 00 00 83 C4 0C 85 C0 74 04 32 C0 EB 17
01592D8Ch:  8B 4D 08 8B 01 6A FF 68 38 2A 5B 01 FF 50 08 8B
01592D9Ch:  45 0C 83 20 00 B0 01 5D C2 10 00 A1 68 82 5B 01
01592DACh:  8B 08 8B 01 FF 20 6A 08 E8 E4 A6 00 00 59 85 C0
01592DBCh:  74 0F 8B 4C 24 04 C7 00 68 2A 5B 01 89 48 04 EB
01592DCCh:  02 33 C0 C2 04 00 8B 44 24 04 56 57 BE 4C 26 5B
01592DDCh:  01 8B F8 A5 A5 A5 A5 5F 5E C2 04 00 32 C0 C3 8B
Stack (0012AA78h):
0012AA58h:  A395F7D8 A395F170 80566A6C 00000001
0012AA68h:  A395F3DC 0000003B 00000083 0075C790
0012AA78h:  0185E220 6E4F6FB4 0012AB44 0012ABF0
0012AA88h:  015D48E8 00000000 00000000 00000010
0012AA98h:  018DB994 00000000 00000000 00000000
0012AAA8h:  018D367C 0193B320 0000001C 0000001C
0012AAB8h:  00000017 018D367C 0193B2C8 0000001C
0012AAC8h:  0000001C 0000000B 00000000 0012ABF0
0012AAD8h:  0012AAF0 0159D4BC 00000004 0187C259
0012AAE8h:  0012AB74 018C2C88 00000001 0185E636
0012AAF8h:  015D482F 01F5BF6C 0012ABF0 00000001
0012AB08h:  00000001 6E4F6E24 01F5BF5C 00000000
0012AB18h:  0012AC54 01F5BDD0 8007000E 0012AB90
0012AB28h:  015B754C 00000000 00000001 015D48E8
0012AB38h:  00000012 003CBB68 018DB994 00000000
0012AB48h:  00000000 00000000 75D1DD87 4AAC9E48
0012AB58h:  25AAA98A BD5AC0D6 018D367C 0193D270
0012AB68h:  0000001C 0000001C 0000000B 0012AC44
0012AB78h:  018C4030 00000005 01863C07 01F5BF5C
0012AB88h:  01F5BF6C 0012ABF0 00000001 6E4F6EAC
Registers:
EAX: 00000000, EBX: 00000000, ECX: 015D48E8, EDX: 015B2A90
ESI: 0012AA9C, EDI: 0012AA9C, EBP: 015D48E8, ESP: 0012AA78
Crash location: "foo_run", loaded at 01590000h - 015BE000h
Loaded modules:
foobar2000                       loaded at 00400000h - 00538000h
ntdll                            loaded at 7C910000h - 7C9C7000h
kernel32                         loaded at 7C800000h - 7C905000h
COMCTL32                         loaded at 77390000h - 77493000h
msvcrt                           loaded at 77BE0000h - 77C38000h
ADVAPI32                         loaded at 77DA0000h - 77E4F000h
RPCRT4                           loaded at 77E50000h - 77EE1000h
GDI32                            loaded at 77EF0000h - 77F37000h
USER32                           loaded at 7E390000h - 7E421000h
SHLWAPI                          loaded at 77F40000h - 77FB6000h
SHELL32                          loaded at 7C9D0000h - 7D1F5000h
ole32                            loaded at 774A0000h - 775DD000h
shared                           loaded at 10000000h - 1002A000h
UxTheme                          loaded at 5B090000h - 5B0C8000h
COMDLG32                         loaded at 76340000h - 7638A000h
IMM32                            loaded at 76320000h - 7633D000h
MSCTF                            loaded at 74690000h - 746DC000h
msctfime                         loaded at 75140000h - 7516E000h
foo_freedb2                      loaded at 00AC0000h - 00B00000h
foo_playcount                    loaded at 00B10000h - 00B3A000h
foo_navigator                    loaded at 00B60000h - 00B94000h
foo_input_wma                    loaded at 00BC0000h - 00BEE000h
WMVCore                          loaded at 7D790000h - 7D99B000h
DRMClien                         loaded at 00C00000h - 00C4F000h
OLEAUT32                         loaded at 770E0000h - 7716B000h
MSACM32                          loaded at 77BB0000h - 77BC5000h
WINMM                            loaded at 76AE0000h - 76B0F000h
msdmo                            loaded at 73600000h - 73607000h
MSVFW32                          loaded at 75BA0000h - 75BC1000h
urlmon                           loaded at 44160000h - 44287000h
iertutil                         loaded at 43E00000h - 43E45000h
VERSION                          loaded at 77BD0000h - 77BD8000h
WININET                          loaded at 44080000h - 44150000h
Normaliz                         loaded at 00C50000h - 00C59000h
WMASF                            loaded at 59A10000h - 59A4C000h
wmidx                            loaded at 4B410000h - 4B439000h
WSOCK32                          loaded at 71A10000h - 71A1A000h
WS2_32                           loaded at 719F0000h - 71A07000h
WS2HELP                          loaded at 719E0000h - 719E8000h
foo_uie_graphical_browser        loaded at 00E90000h - 00F24000h
MSIMG32                          loaded at 76310000h - 76315000h
gdiplus                          loaded at 4EB80000h - 4ED26000h
foo_infobox                      loaded at 00F50000h - 00F90000h
foo_uie_albumart                 loaded at 00FB0000h - 00FED000h
foo_input_mslive                 loaded at 01010000h - 01051000h
foo_dsp_std                      loaded at 01080000h - 010C8000h
foo_uie_quicksearch              loaded at 010F0000h - 01136000h
foo_uie_lyrics                   loaded at 01160000h - 011BC000h
foo_uie_lyrics_panel             loaded at 011E0000h - 01244000h
foo_whatsnew                     loaded at 01270000h - 012B0000h
foo_converter                    loaded at 012D0000h - 0133C000h
foo_ui_std                       loaded at 01360000h - 01434000h
foo_unpack                       loaded at 01460000h - 0148D000h
foo_abx                          loaded at 014B0000h - 014E1000h
foo_rgscan                       loaded at 01510000h - 0156B000h
foo_run                          loaded at 01590000h - 015BE000h
foo_fileops                      loaded at 015E0000h - 01626000h
foo_uie_vis_peakmeter_spectrum   loaded at 01650000h - 0168F000h
foo_uie_trackinfo                loaded at 016B0000h - 016D5000h
foo_uie_trackinfo_mod            loaded at 01700000h - 01756000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_menu_addons                  loaded at 01780000h - 017C5000h
foo_ui_columns                   loaded at 017F0000h - 0191D000h
foo_utils                        loaded at 01940000h - 01984000h
foo_cdda                         loaded at 019B0000h - 019F1000h
foo_uie_vis_channel_spectrum     loaded at 01A20000h - 01A5D000h
foo_misc_addons                  loaded at 01A80000h - 01AAA000h
foo_snarl                        loaded at 01AD0000h - 01AF2000h
foo_uie_elplaylist               loaded at 01B20000h - 01B87000h
foo_dbsearch                     loaded at 01BB0000h - 01C20000h
foo_input_std                    loaded at 01C40000h - 01D79000h
foo_albumlist                    loaded at 01DA0000h - 01E0B000h
mscms                            loaded at 73A80000h - 73A95000h
WINSPOOL                         loaded at 72F50000h - 72F76000h
icm32                            loaded at 58A10000h - 58A51000h
libpng13                         loaded at 036A0000h - 036E5000h
zlib1                            loaded at 03700000h - 03728000h
imagehlp                         loaded at 76C40000h - 76C68000h
DBGHELP                          loaded at 5D3F0000h - 5D491000h
Stack dump analysis:
Address: 0185E220h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 018DB994h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 018D367Ch, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 0159D4BCh, location: "foo_run", loaded at 01590000h - 015BE000h
Address: 0187C259h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 018C2C88h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 0185E636h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 015B754Ch, location: "foo_run", loaded at 01590000h - 015BE000h
Address: 018C4030h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 01863C07h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 7E39B3BCh, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefWindowProcW" (+00000090h)
Address: 7E39B397h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 018C72DEh, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 01864136h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 7E39C129h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetClassLongW" (+00000030h)
Address: 7E398896h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetWindowLongW" (+00000000h)
Address: 7E39D3C6h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "EnumDisplayMonitors" (+0000047Bh)
Address: 7E398B16h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 0188FFB0h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 7E3988C1h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 7E3988CAh, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 018C7750h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 7E3C0477h, location: "USER32", loaded at 7E390000h - 7E421000h
Address: 01890146h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 7E398724h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E39D043h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "EnumDisplayMonitors" (+000000F8h)
Address: 7E398820h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetDC" (+00000169h)
Address: 7E39B4B0h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 7E39B4C0h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 7E39FD09h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "UserClientDllInitialize" (+000007F1h)
Address: 7C91EAE3h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 017F0000h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 018D9200h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 7E39B463h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 7E3A011Eh, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "CreateWindowExW" (+000001EEh)
Address: 7E3A00E4h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "CreateWindowExW" (+000001B4h)
Address: 7E3A0109h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "CreateWindowExW" (+000001D9h)
Address: 7C9205D4h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 01B6B618h, location: "foo_uie_elplaylist", loaded at 01B20000h - 01B87000h
Address: 01B38240h, location: "foo_uie_elplaylist", loaded at 01B20000h - 01B87000h
Address: 01B3B300h, location: "foo_uie_elplaylist", loaded at 01B20000h - 01B87000h
Address: 7C920732h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C91EE18h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "strchr" (+00000117h)
Address: 7C921538h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C921596h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9206EBh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C927C0Ch, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReAllocateHeap" (+0000020Fh)
Address: 7C927BF5h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReAllocateHeap" (+000001F8h)
Address: 7C927BB0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 7C920738h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C9206ABh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7E399481h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetWindowLongA" (+00000034h)
Address: 7E3994AEh, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 7E39B41Dh, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefWindowProcW" (+000000F1h)
Address: 7E39B3E9h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 5B091AF6h, location: "UxTheme", loaded at 5B090000h - 5B0C8000h
Address: 7C9205C8h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C920551h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C92056Dh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 5B091B3Dh, location: "UxTheme", loaded at 5B090000h - 5B0C8000h
Address: 7E398BC9h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 7E3F1088h, location: "USER32", loaded at 7E390000h - 7E421000h
Address: 018417D2h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 0189C560h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 01898BC9h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 01898BE8h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 7C9206F0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 7C920570h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7C920833h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+0000025Fh)
Address: 017F0108h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 7C920838h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000264h)
Address: 7E3A01D7h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "CreateWindowExW" (+000002A7h)
Address: 018F902Ch, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 018BE388h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 018613D8h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 018613F1h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 018BECF8h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 7E39FF63h, location: "USER32", loaded at 7E390000h - 7E421000h
Symbol: "CreateWindowExW" (+00000033h)
Address: 0188FE31h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 018D9AF4h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 017FC524h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 0183EBC0h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 018D50CCh, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 018D6E60h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 0101BB88h, location: "foo_input_mslive", loaded at 01010000h - 01051000h
Address: 018C31CEh, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 0183FE0Ah, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 018D6E80h, location: "foo_ui_columns", loaded at 017F0000h - 0191D000h
Address: 01B22D90h, location: "foo_uie_elplaylist", loaded at 01B20000h - 01B87000h
Address: 01B579E9h, location: "foo_uie_elplaylist", loaded at 01B20000h - 01B87000h
Address: 01B72F88h, location: "foo_uie_elplaylist", loaded at 01B20000h - 01B87000h
Address: 01B72F80h, location: "foo_uie_elplaylist", loaded at 01B20000h - 01B87000h
Address: 01B72EB0h, location: "foo_uie_elplaylist", loaded at 01B20000h - 01B87000h
Version info:
foobar2000 v0.9.6 beta 3
UNICODE
Windows 5.1
Additional info:
Special file info box 2.0.4  (foo_infobox)
Acro WMA decoder 0.1.7.2 (SSE)  (foo_input_wma)
CD Audio Decoder 2.1.3  (foo_cdda)
ReplayGain Scanner 2.0.8  (foo_rgscan)
Run services 0.3.4  (foo_run)
Channel Spectrum panel 0.17.2  (foo_uie_vis_channel_spectrum)
Misc. Addons 0.1.4 (SSE)  (foo_misc_addons)
ABX Comparator 1.3.3  (foo_abx)
Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]  (foo_uie_trackinfo_mod)
Lyric Show Panel 0.3.3.3 [Sep 23 2008 - 14:15:11]  (foo_uie_lyrics)
Standard Input Array 1.0  (foo_input_std)
ELPlaylist 0.6.2.8(beta)  (foo_uie_elplaylist)
Lyrics panel 0.35  (foo_uie_lyrics_panel)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Feature Watcher 1.0.6  (foo_whatsnew)
ZIP/GZIP reader 1.0  (foo_unpack)
Navigator 0.63  (foo_navigator)
Album List 4.3  (foo_albumlist)
Peakmeter Spectrum Visualisation 0.1.0.2 beta  (foo_uie_vis_peakmeter_spectrum)
Converter 1.2  (foo_converter)
Playlist Tools 0.6.2 beta 6  (foo_utils)
Album Art Panel 0.2.7.1  (foo_uie_albumart)
Database Search 1.4  (foo_dbsearch)
Graphical Browser rev015  (foo_uie_graphical_browser)
File Operations 2.1  (foo_fileops)
Columns UI 0.3.4.2  (foo_ui_columns)
foo_snarl 0.0.1.5  (foo_snarl)
freedb Tagger 0.6  (foo_freedb2)
Track info panel 0.8  (foo_uie_trackinfo)
RAR reader 1.1  (foo_unpack)
Default User Interface 0.9.5  (foo_ui_std)
mslive 0.4.8 (SSE)  (foo_input_mslive)
Menu Addons 0.4 (SSE)  (foo_menu_addons)
Standard DSP Array 1.0  (foo_dsp_std)
Playback Statistics 2.1.6  (foo_playcount)
foobar2000 core 0.9.6 beta 3  (Core)
If any can help me it would be very nice
