Topic: foo_musical_spectrum (discussion) (Read 11537 times) previous topic - next topic - Topic derived from foo_musical_spectrum
Re: foo_musical_spectrum (discussion)
Reply #125
Hi all. I can't wait to use this addon. As a new user to foobar2000, i have encountered an error on loading. i have the 64bit version installed and am receiving this error on launch
Failed to load DLL: foo_musical_spectrum.dll
Reason: Not a valid Win32 application.
Am i correct in assuming it will only run on the 32bit version?
TIA
Reply #126
TIA
Correct, this component is 32-bit only as the original dev (@fismineur) was gone, so I suggest using foo_vis_spectrum_analyzer if you want that
Reply #127
TIA
Yes. It's 32bit only.
A remake (and then some) is available here.
