Topic: iPod manager (Read 2265474 times) previous topic - next topic
[seemingly abandonware] iPod manager
Reply #350
But in your case - filetype not supported by iPod - it should be fairly straightforward to make it transcode them to separate files.
Yes, that is all I am looking to do. All of my music is backed up to flac images, so just to be able to transcode miscellaneous tracks from the image would be terrific for my situation.
At the moment, here at work, I only have single FLAC files to transcode and I have been able to transcode full 12 track albums at once without a problem.
Merry Christmas and Happy Holidays!
Surf's Up!
"Columnated Ruins Domino"
Reply #351
musicmusic,
Great plugin!!!
Currently using the 0.3.6 test version and so far so good.
iTunes just blew.  The Winamp plugin works, but hated going back and forth from it and fb2k.  Now I can ditch Winamp.
Keep up the fantastic work man!!!  Looking forward to any and all enhancements/improvements...
Reply #352
Could you add tag mapping for the rating?
Reply #353
iPod Shuffle - Possible: yes. Planned: not right now.
Wow! Thanks! I'm the first to use it when it comes available!
Reply #354
There is a new special version available that needs testing here. It has a new background monitor for iPod connection/disconnections and also now detects iPods by their Device Instance ID (which means it will detect iPods without iTunesDB present).
However, this needs testing to see if it is working correctly. Please check with the test version to see if it still detects your iPod (e.g. try load library command) - especially if it is connected by firewire. If it does not, there should be some messages about drives in the foobar2000 console - just paste them here and tell me your iPod drive letter. Note: I don't really want it used for anything else other than to test this.
I'm also collecting VIDs/PIDs etc. for different iPods. These can be gotten from the console messages the test version outputs (see next link for more info). I'm especially interested if all iPods have the same IDs over firewire. I've put what I know so far here but a lot of it is second hand info. Please fill any gaps and make any corrections. Thanks!
I'm not sure you understood what I meant..
Reply #355
Hi musicmusic,
I connect by firewire and the new test version detected my iPod and loaded the library without a problem.
Also, I have a 3G and the console reads:
Startup time : 0:16.460685
iPod connected at M: Device Instance ID: 1394\APPLE_COMPUTER__INC.&IPOD\1670C202270A00
Surf's Up!
Reply #356
iPod connected at E: Device Instance ID: USB\VID_05AC&PID_1203\0000004E75DC
4G (grey)05ac 1203 works okay
Reply #357
My Grey 4G says:
iPod connected at G: Device Instance ID: 1394\APPLE_COMPUTER__INC.&IPOD\87857D02270A00
I'll add this to the wiki table.
Reply #358
Nano 2G:
iPod connected at G: Device Instance ID: USB\VID_05AC&PID_1260\000A2700188F8614
Works fine.
Reply #359
Can someone please post on how to get the Device instance ID?
Reply #361
Thank you all for testing. Good enough success rate for me
I uploaded final 0.3.7 TEST to my homepage. Details in changelog. I removed the console messages that were present in the earlier version also.
Reply #362
Hi musicmusic,
I just wanted to let you know that transcoding from my FLAC image files is working perfectly. Thank you very much for including this in the final 0.3.7 Test version.
Happy New Year!
Surf's Up!
Reply #363
Your welcome
Now to anyone who wants Shuffle support, I wouldn't mind a backup of the iTunes\iPod_Control folder of a Shuffle that has only been used with iTunes (it should compress well with 7-Zip). Thanks!
Reply #364
iPod 3G with firewire.
Startup time : 0:03.429382
drive H: installed Device Instance ID: HTREE\ROOT\0
No iPod found!
EAC (Secure Mode) / LAME 3.97 (-V 2) / fb2k / M-Audio 24/96
Reply #365
This might be a really obvious question, but could someone tell me what field I'm supposed to map %album artist% to? Is that was composer is for? The documentation says it's supported but all my VA albums are spread around.
Reply #366
iPod Mini 1G via firewire
Windows Vista RTM
drive N: installed Device Instance ID: HTREE\ROOT\0
No iPod found!
Reply #367
Same as above, I tried USB also - it doesn't work either.
Reply #368
OK, it wasn't working in Vista, because the volume isn't a child of the iPod's disk anymore in the device tree.
I used some funky tricks to match the iPod volume to the iPod disk without using admin priviledges or WMI (which is slooow). I tested it on XP SP2 and Vista RC2 where it works for USB iPods. Can you people who had problems and firewire people check if it works for you. The new version to test is located here. Note: it is only to check if it works or not. There's no console messages.
Reply #369
The new version works for me. I'm using Vista and firewire. And thank you VERY much for this component by the way!
Reply #370
Yes it works under Vista now (both firewire and usb)!
And huge thanks for the great on-the-fly converter!!
Reply #371
Ok, I am probably being massively stupid here, but could someone help me out with the converter. I have tried every possible combination of codes I could reasonable think of.
What I want to do is to add properly tagged LAME V2 MP3s to my IPOD I am using this code
command:
C:\lame.exe -S --noreplaygain -V 2 --vbr-new - %d
Extension:
mp3
The failure I get is
Reason: Conversion failed - encoder failure
Presumably I don't have to convert to .wav before the conversion, do I?
If someone could post a successful code, I would be most grateful.
musicmusic, thankyou so much for this superb plugin.
Reply #372
Could you add a "copy" feature, so if you use it, instead of transcoding a not supported file, foo_dop would just copy it like foo_sendtodevice? That way, foo_dop would be perfect for Rockbox/Apple OS use
I hope you understand what I mean
Reply #373
another thing - it seems that the "omit the when sorting" feature works, but scrolling songs on the iPod results in "A, T, B, T, C, T..." is this fixable?
Reply #374
Good, thanks for checking, and you are both welcome
command:
Extension:
mp3
You're command works fine here, so I don't think that is at fault. What version of LAME are you using? Try 3.97. What is the input file format? Try a different one. It may be specific to that format in which case I can fix it.
I don't want to put unsupported formats in the iPod's db, it's only going to confuse the iPod and me also. Okay, maybe you don't want them in the iPod's DB but anyways sorry I don't plan to add this at the moment
Hmmm.... I don't think its fixable without making the songs list as "..., The". Do you know what iTunes does?
iPod Shuffle Test Version
Thanks to the person who sent me their Shuffle iPod_Control\iTunes folder, I was able to attempt to implement Shuffle support.
Note: It has the following limitations:
-I don't own a Shuffle. Therefore I don't know if it even works or just send Shuffles into Oblivion.
-Make sure you backup your iPod_Control\iTunes folder before use
-It doesn't preserve the original song order. I.e., first time you use foo_dop, the song order will change. In addition, songs sent using foo_dop will appear in an arbitrary order.
-Doesn't merge play counts back into the DB. Doesn't support start/stop times. Resets the Shuffle's volume and shuffle status when updating the Shuffle.
-Don't know how foo_dop and DRM'd songs already on the Shuffle mix.
Test version download I am interested to know if it actually works (can you listen to added songs etc.)
I'm still interested in iPod_Control\iTunes backup of a shuffle that has been used a fair bit and has many songs on it and has only been used with iTunes.
