Topic: NEW ESLyric v0.5 - an alternative lyric show component (Read 35604 times) previous topic - next topic
Re: NEW ESLyric v0.5 - an alternative lyric show component
Reply #103
enhanced lyrics = sync lyrics ?
https://github.com/ESLyric/release/wiki/%E6%AD%8C%E8%AF%8D%E6%BA%90%E5%8F%8A%E8%A7%A3%E6%9E%90%E5%99%A8%E8%84%9A%E6%9C%AC#:~:text=%E5%A4%9A%E6%A0%87%E7%AD%BE%E5%A2%9E%E5%BC%BALRC%20(%E8%A7%81wiki%20Enhanced%20format%E9%83%A8%E5%88%86%E8%AF%B4%E6%98%8E)
https://en.wikipedia.org/wiki/LRC_(file_format)
Thank you. I understand.
[00:00.00]line 1
[00:01.00]line 2
Lyric Processor can
[mm:ss.xx] <mm:ss.xx> line 1 word 1 <mm:ss.xx> line 1 word 2 <mm:ss.xx> ... line 1 last word <mm:ss.xx>
[mm:ss.xx] <mm:ss.xx> line 2 word 1 <mm:ss.xx> line 2 word 2 <mm:ss.xx> ... line 2 last word <mm:ss.xx>
Lyric Processor cannot
Reply #104
Background Image, is it possible to specify a folder as the Image source and target all images under the folder?
I would appreciate it if this could be done.
Reply #105
Just an FYI... If your theme is portable, ESLyric will not work if there is an apostrophe in your folder name. It won't even list or load sources.
Reply #106
My apologies. My mistake.
The image files in the folder were all in webp format.
I converted them to jpg and they displayed fine.
Reply #107
Good day guys,
First time posting  :)
I have a couple questions about ESLyrics:
I'm trying to set a background picture but I don't see the "panel preferences" as on the developer (picture #1) instead I see the one with the "display configuration" (picture #2), Am I missing something?, do I need another plugging to show it? (I'm running version 0.5.4.1028)
Second questions is, if is possible to have a second line to show when the lyrics is too long...Right now what it does is that it scrolls from right to left (I f I go to  "Desktop lyrics" (Picture #2) I have a field call "line(s) and there I can chose "single line" and "double line" but this make the Lyric that is coming in to show on the top line which is not ideal.
Thanks in advance for your help!
Best regards.
Reply #109
Good day guys,
Best regards.
The panel preferences you search is in the panel right click
X
Reply #110
Hello Paregistrase,
And thank you for the quick reply.
Sorry I did not say that I want the background for "desktop lyrics" not for the UI panel.
Reply #111
Hello Paregistrase,
I don't think that you can set a background, the whole point is that it is transparent to be able to see the lyrics over other things you're doing.
IMaybe you can use https://hydrogenaud.io/index.php/topic,90977.0.html to make a poup window with the lyrics. It is a bit fake solution but it can have background picture, and it is movable.X
The window with the lyrics can be moved, resized and have the same configurations of a lyrics panel inside foobar2000
Reply #112
Hello Paregistrase,
And thank you for the reply.
Reply #113
When Panel and Desktop Lyric are displayed at the same time,
Panel does not show the enhanced lyrics, but the Desktop Lyric does,
What does this mean?
This title I can't find any enhanced lyrics in "Search".
Reply #114
Sorry.
The panel has three "Karaoke modes".
Off
Always on
On when show enhanced lyric
For Desktop, Karaoke mode is either "Off" or "On".
Probably, Desktop  when "Karaoke mode" is "On".
If it is "sync lyrics", it shows "enhanced lyric".
I guess it is like that.
Reply #117
Found a memory leak bug. If the image artwork is turned on, foobar2000's memory climbs with every track that is played,
Reply #118
ESL has a internal images cache, and will do GC when necessary.
Reply #119
Ok, thanks! I changed pref.image.cache.limit from 16 to 1 and I noticed that around 1100mb the cache reset.
Reply #120
Also users should delete "LyricsOnDemand" from their source list due to memory leak/not working status.  The developer has removed it from the install list (https://github.com/ESLyric/feedback/issues/149) .
Reply #121
Because of the rather bad foobar-x86 start and shutdown experience with multisource 0.5.6 enabled and not getting feedback on my bug report, I'm migrating to ESlyrics.
Great to see ESlyrics supports transparency so I can paint my own background and display my own art underneath ESlyrics.
I also like dragging lyrics to continue playing from the point I drag the lyrics too.
I've read this whole topic and have some questions.
1) Doubleclicking changes ESlyrics to fullscreen. The fonts/colors used in this mode are different from those I specified in Panel Preferences.
Where can I change behavior for doubleclick (I'm not interested in fullscreen lyrics), I'd rather open Search, Preferences or PanelPreferences. Or disable doubleclicking altogether.
2) How can I adjust offset other than entering a value in ms? In LS3 I can use my mousescrollwheel to adjust offset on the fly which is very convenient.
3) In LS3 I can use [%search_state%][ %search_progress%'%'] in fallback text to show progress upon searching for lyrics. Does ESlyrics have similar variables?
4) I noticed a lot of discussion about %album%. I typically use %album% like "Strangers in the Night [Live] [1999 UK 724352081028]" and strip this down to "Strangers in the Night" where needed. In ESlyrics I can enter the TF for artist and title, but not for processing %album%. Where can I do that?
5) I installed Sveakul's modified scripts for metallum and minilyrics, but so far did not get any hit for those two plugins even searching for the easiest stuff like for instance "Van Halen - Little Dreamer" (which of course is found via all the other search scripts). What am I doing wrong?
Reply #122
Hi Defender--you should try posting the bug report to the actual LSP3 thread, which is where Veksha seems to post the most:
https://hydrogenaud.io/index.php/topic,90338.0.html
As far as my two modified scripts for ESLyric, they are designed specifically for use with radio streams, which almost never send album name data.  You should use the ones for Metallum and Minilyrics that are already included in ESLyrics if your searching is for actual music files that include embedded album name tags.  You can keep both versions and just un-check the mod ones when you are not listening to radio streams.
Reply #123
Thx. I'll forward my multisource problem post in the LSP3 thread.
I do listen a lot to radio streams, but I wasn't aware your modified scripts were only active on radiostreams. Will check now.
EDIT: Yes, your modified metallum script found lyrics for King Diamond.
Reply #124
0.5.3.1020
 - Unified panel with desktop lyrics mouse shortcut operation:
    Ctrl + Scroll Wheel to increase/decrease the font
    Shift + Scroll Wheel to adjust the lyrics offset (it is recommended to adjust it after turning on the karaoke display mode)
    Ctrl + Alt + Scroll Wheel Previous/Next sentence
There is no solution to other problems for the time being, and the specific changelog can be found on github for details
https://github.com/ESLyric/release/releases/tag/0.5.3.1020
