Topic: Monkey Woe (Read 4739 times) previous topic - next topic
Monkey Woe
I have wapet and Monkeys Audio installed in EAC but I cannot get the compression to function. For the Wapet instalation I have C:\Special\wapet.exe. For the monkey instalation I have C:\Special\Monkey's Audio\MAC.exe. When I record with EAC at time of compresion I get the error message "The system cannot find the path specified". Obviously I am making some very basic error. What might it be?
Monkey Woe
Add quotes.
Monkey Woe
' date='Oct 7 2006, 19:20' post='438901']
Add quotes.
If you mean to put C:\Special\Monkey's Audo\MAC.exe in quotes in the additional command line options block in EAC (along with all the other entries) I had already done that. I have it as %d -t "Artist=%a" -t "Title=%t" -t "Album=%g" -t "Year=%y" -t "Track=%n" -t "Genre=%m" "C:\Special\Monkey's Audio\MAC.exe" %s %d -c4000. Thoughts?
Monkey Woe
Here's my command line:
/c ""C:\Program Files\Exact Audio Copy\wapet.exe" %d -t "Artist=%a" -t "Title=%t" -t "Album=%g" -t "Year=%y" -t "Track=%n" -t "Genre=%m" "C:\Program Files\Exact Audio Copy\MAC.exe" %s %d -c3000%c &&"C:\Program Files\Exact Audio Copy\MAC.exe" %d -v%c"
When using cmd.exe and /c, a set of quotes gets removed, so a second set has been added.
Monkey Woe
I tried your command line with my paths to no avail. I don't think its the paths either so it must be something else.  I probably should just erase everything, download new, reinstall and start over ( or go buy an Olive).
Monkey Woe
There is more to getting this right than just the command line.  Did you make sure the other settings are correct?
Parameter scheme: User Defined Encoder
Extension: .ape
Program: C:\Windows\system32\cmd.exe
Monkey Woe
Don't worry about me, I had a problem but have got it sorted now.
