Topic: Resurrecting/Preserving the Helix MP3 encoder (Read 12091 times) previous topic - next topic
Re: Resurrecting/Preserving the Helix MP3 encoder
Reply #100
This might actually warrant rolling back to writing "Xing" in the header, even for CBR files. fb2k might be fixable, but Windows isn't.
That would be the quicker fix, I guess. Lame writes a full size Xing/Info tag even for CBR files and everything reads it correctly. I've been trying to figure out where the hmp3 tag writing differs that causes the issue. Clearly the lame written tag includes more info as it was designed for lame and the hmp3 code either doesn't generate the same information, or doesn't use the same functions/variables, but I believe there must be some other fundamental point that I'm missing! I will continue to try to find it!!
Reply #101
Hmmm... one thing I did change: If the file is CBR, I do not include the the Xing VBR Table of Contents (TOC). This makes the header smaller and thus fits into more CBR frame sizes. What happens if you comment out lines 241 and 242 in xhead.c?
Reply #102
Thanks for all the explanations.
Please carry on  :)
Reply #103
If I leave the header as 'Xing' and re-enable the TOC, all is OK except that fb2k calls it VBR. Lametag 0.3.1 recogises the tag as expected. If I then change the header to 'Info', all is good except that Windows now ignores the delay/padding, but Lametag 0.3.1 still reads the tag correctly. I know Windows is a law unto itself but since the lame 'Info' tag is read correctly by Windows, there must be something included in the lame written tag that is missing from the hmp3 written tag that is important to Windows. The question is, what?!?!
Edit: On reflection, I think it likely that Windows is probably expecting one, or more, positions in the tag to be filled with data that hmp3 doesn't generate, or can't fill because the encoder internals are different and the data isn't available in a suitable format. Unless someone has a bright idea, it's probably simpler to use the 'Xing' tag + TOC and perhaps Peter can tweak fb2k to see it as CBR, or otherwise just live with it.
Reply #104
Okay, I think I got this fixed.
Turns out that for CBR the size of the first frame (where the info tag is stored) was only half of what it was supposed to be - because in the Helix MP3 encoder, the bitrate is set *per channel*, but I forgot to multiply the bitrate by the number of channels.
Thus "CBR" files were not _actually_ CBR, because the first frame was smaller than the rest. This most likely lead fb2k to say "VBR" (not all frames are of equal size), and I guess Windows got confused as well.
I now also write the TOC into CBR files, unless the bitrate is very low.
Reply #105
Ladies and Gentlemen, I believe we have a winner! This now appears to meet all demands. Should we bump to 5.2.1 as this is not an insignificant fix?
Reply #106
I don't think we should burn through the version numbers quite that quickly, as I don't assume anyone really mass-encoded with the daily builds ;-)
Reply #107
Rarewares compile updated. :)
Reply #108
Reply #109
Thank you, experts, for further improving such a legacy MP3 encoder!
Over the past years i used mp3guessenc for analyzing MP3s. This tool also verifies the LAME tag in some way. This "Tag verification" check fails with the hmp3 encoder.
Could this also be relevant, referring to the prior compatibility discussions? I'm not a developer, so I'm not that experienced in reading source codes to find an answer myself.
Reply #110
lametag 0.3.1 reads the tag fine, but 0.4.1 does not. I can't speak for mp3guessenc, but I suspect it depends on how specific the software is in needing lame specific information. It could even be that it fails because the version characters of the lametag are not 3.xxx, but I am only guessing. Without knowing the specific determing factors that mp3guessenc uses, further comment is irrelevant.
However, lame decodes hmp3 encoded files correctly, so I would believe that it's a software problem rather than a 'tagging' problem.
Reply #111
Hello,
I don't know if it has already been reported: tag part of tagged WAV files is encoded as if it was PCM.
    AiZ
Reply #112
Hello,
    AiZ
I presume you are taking about id3 tagged wav files which may be so, but then wav files shouldn't be id3 tagged in the first place.
Reply #113
Hi John,
You're right, problems come with id3 tags, RIFF tags are Ok.
    AiZ
Reply #114
Oh, that's perfectly expected. The info tag has fields for 16-bit checksums (tag checksum, MP3 checksum). Those fields are currently left "empty" (filled with zeros), so there's no checksum information to check against.
Reply #116
Thank you for your explanations, John and maikmerten.
Reply #117
Maybe it's just me, but it seems like the correct tagging approach should be to write HELIX instead of LAME, and then have other programs like foobar2000 update to support the existence of multiple MP3 encoders, rather than writing "LAMEH" or similar by default to trick other programs into thinking LAME was used.
There ought to be a switch to enable this behaviour if you need your MP3s to work on some old software that will never get updated, but the fact that other software developers have required the string "LAME" in the tag seems to me like their problem, not yours, and it would be better if they updated their programs, rather than you being forced to use hacks by default in yours.
Reply #118
fb2k plays and decodes correctly with a 'HELIX5.20' header, as do some other players, and lame decodes such a file correctly. The versions of lametag that I have fail to read the tag with the Helix header and the chances are that there are many pieces of software in use that will fail at some level where the chances of the necessary changes being implemented are negligable. So, although I agree with you philosophically, pragmatically it is probably better to stick with what it is currently.
Reply #119
The problem really is that there is little development interest in MP3 these days. I don't expect a lot of playback software to get updated to read something like "HELIX5.20" properly (which I'd prefer, of course). This might lead to some user frustration with, e.g., gapless playback not working properly and updates needing months or years to tickle down to users.
Also note that "LAMEH5.20" includes all the information necessary to identify it as a Helix file - if there's a "H", it's Helix.
This is very much like LAME having to write "Xing" into the info header for players to recognize the Xing-VBR tag, despite not being Xing, obviously. We've now come full-circle, with LAME using "Xing" and Xing/Helix using a "LAME"-prefix.
Reply #120
Mathie: "Two wrongs don't make a right!"
Engineer: "If it makes a workable ...?"
Patching up lossy codecs' old sins falls into the engineering category. Go ahead with it if it works.
There is an aside here: Back in the day when Xing was called Xing, did other encoders write headers such that (later?) tool would (mis-)identify them as "Xing" encodes? Anyone remembering them early days of the industrial revolution? :)
Reason why I am asking is that - although I don't remember twenty-five year old artifacts and that kind of thing, I remember that "Xing-identified" files could be quite crappy. But that impression may also have stuck out of all the things people did back then, like for example "merging MP3s by concatenating the files". Hey if there were no tags, it wouldn't be too bad, at least not when MP3s wouldn't be completely gapless anyway. And if there only was an ID3v1 ...
But if there were other "worse" (audio quality or header implementation!) codecs that would identify or be mis-identified as "Xing", and would later die out ... would explain something.
Reply #121
Well, Xing had a VBR header SDK for implementation in other encoders: http://www.mp3-tech.org/programmer/sources/vbrheadersdk.zip
That one also includes writing "Xing" to the header frame, so I guess many tools of the era would mis-identify VBR encodings with that header as being "Xing".
Reply #122
One more thing - the code compiles smoothly and without errors using MinGW/GCC. Thumbs up.
The ASM code path is only used when compiling with Visual C++/VS - is that correct?
But never mind - the optimization via CFLAGS provides a pretty fast GCC binary as well.  ;D
Reply #123
Yeah, the ASM path should be Visual C++/VS only. And then only for 32 bit compiles.
With modern compilers and instruction sets, the C compiles may not fare any worse. I think John did some speed testing and the 64 bit C-compiles fared very well.
Reply #124
Sadly, that seems to apply to all lossy audio these days. I guess it's reached "good enough" status, and nobody has any practical ideas on how to improve things beyond the capabilities of AAC/Opus.
