Topic: Mp3tag 3.18 (Beta) (Read 490 times) previous topic - next topic
Mp3tag 3.18 (Beta)
3.18a (2022-10-07)
CHG: extended error message when writing too large cover art to FLAC.
CHG: information field %_id3v2_unknown_frames% now reports the ID3v2 frame identifiers.
FIX: runtime error at right click on cover window of non-audio image file with 64-bit version.
FIX: MusicBrainz tag source issue with artist names containing vertical bar character.
https://community.mp3tag.de/t/mp3tag-development-build-status/455
Mp3tag is a powerful and easy-to-use tool to edit metadata of audio files.
It supports batch tag-editing of ID3v1, ID3v2.3, ID3v2.4, iTunes MP4, WMA, Vorbis Comments and APE Tags for multiple files at once covering a variety of audio formats.
Furthermore, it supports online database lookups from, e.g., Discogs, MusicBrainz or freedb, allowing you to automatically gather proper tags and download cover art for your music library.
You can rename files based on the tag information, replace characters or words in tags and filenames, import/export tag information, create playlists and more.
"The lack of money is the root of all evil." - Mark Twain
Re: Mp3tag 3.18 (Beta)
3.18b (2022-10-28)
CHG: uninstaller has now a checkbox to explicitly enable removing of configuration data instead of confirmation dialog.
FIX: cover type couldn't be changed via extended tag dialog (since v3.16b).
FIX: tracks frame wasn't resized correctly at Tag Sources confirmation dialog.
FIX: previous start menu folder wasn't used when updating 64-bit version.
