Topic: Pls walk me through steps for getting my fb2k to load and play DSD files (Read 542 times) previous topic - next topic
Can someone please walk me through the step by step of getting my new installation of fb2k to play DSD files?
I've just read the post by Yirka about the rules for using this forum, and I have to say that my issue seems to fall squarely in the middle of all three of his categories. So here goes:
The Issue: I am trying to load fb2k, newest version download (= v. 2.0 X64), in the hopes of playing high resolution files. And having only mixed success. I can play DXD files up to 24/384,000 , but not dsd.
I'm having the following problems:
So far I have not even been able to get fb2k even to load .dsf files, let alone play them.
I tried installing the usual fb2k adding components sourced from the Foobar website:
FOO_OUT_ASIO.FB2K-COMPONENT
FOO_OUT_WASAPIS.FB2K-COMPONENT
(downloaded from NativeDSD website):
foo_dsd_processor.fb2k-component
foo_input_sacd.fb2k-component
But ran into the following error message/obstacle:
"Components that are either included with the Foobar 2000 installer or have been installed manually in your full bar 2000 application folder are shown as grayed out. they cannot be automatically uninstalled or updated from within fubar2000."
the instructions in the pop up box go on to say
"If you wish to automatically update add-on components that are grayed out please rerun the Foobar 2000 installer and choose to move your components to your personal folder."
Also on start up I get the following error message:
"Failed to load DLL: foo_out_wasapi.dll
reason: not a valid Win32 application
Failed to load DLL: foo_out_asio.dll
Failed to load DLL: foo_out_sacd.dll
reason: not a valid Win32 application"
Here are my system specs:
PC = Dell E6340
OS = Windows 7 Professional 64-bit, Service Pack 1
CPU Intel core i7-3520M CPU @2.90 GHz
RAM = 16 GB
DAC = iFi Pro iDSD (driver successfully loaded and working with fb2k)
I've also included some screenshots from my fb2k installation:
[FB2K startup error scrn.jpg]
[fb2k 'Components' list.jpg]
Thanks in advance, : GeorgeNJAudio, NJ USA
Re: Pls walk me through steps for getting my fb2k to load and play DSD files
Apologies for the length of this post, but keep in mind that I'm a newbie here, and was trying to cover all the bases. GeorgeNJaudio
I'm not familiar with DSD, I'm sure someone will show you how to set it up...
Make a clean install of foobar2000, then install these components:
https://sourceforge.net/projects/sacddecoder/files/
foo_input_sacd
foo_out_asio+dsd
32-bit components will not work with 64-bit foobar2000, but the above will (they contain both 32 and 64 bit builds).
foo_out_wasapi.dll
foo_out_wasapis.dll
foo_out_asio.dll
No need for any of these components. The first two are now part of default foobar installs (different implementations) and the last one, the alternative foo_out_asio+dsd component linked above is newer and probably preferred.
In Preferences > Playback > Output, selecting a <device name> uses WASAPI Shared output (uses Windows mixer / resampler, allows other sounds), while selecting a <device name> [exclusive] uses WASAPI Exclusive output ("bit-perfect" direct to DAC, no other sounds). So try selecting an [exclusive] output for DSD, or otherwise ASIO+DSD <device name> can also be used and might work better. (Click OK/Apply)
In Preferences > Playback > Output > ASIO+DSD, might as well try out 'Use 64-bit ASIO drivers' - not sure makes any difference but why not...
In Preferences > Tools > SACD, under Output > Type select DSD and try playing something, or if that does not work try DSD+PCM. (Note this setting is per device, so if you change output <device name> you might need to set this again)
(Beyond that I have not a lot of experience bothering with DSD, other folks can probably provide better information)
Obligatory comment:
WavPack can losslessly compress DSD (but you have to use the WavPack executable, not a transcoder like fb2k).
Check if that makes a difference?
foo_input_sacd
foo_out_asio+dsd
thank you, Gus! Looks promising.
foo_out_wasapi.dll
foo_out_wasapis.dll
foo_out_asio.dll
thanks, anamorphic! Looks promising will get back to you
Obligatory comment:
thanks but I'm not sure this applies to my issue. He DSD files I download from the websites I buy them from our already compressed when I download them.
foo_input_sacd
foo_out_asio+dsd
Gus: thank you thank you thank you! Your recommendations for the fix worked well, >EXCEPT< that when I try to play DXD files (& I have a lot of those) I get this fb2k error message: "Unrecoverable playback error Sample rate of 352800 Hz not supported by this device." BUT I know that my "device" – an iFi  Prod iDSD DAC-- plays 24/352,800 Hz and higher DXD. So the error message must be referring to my fb2k setup I'm guessing. Maybe I need to add another component? Please advise.
Help me fix this issue and I will be golden!
This is beyond my experience/knowledge...
For testing purposes, try one of the [exclusive] outputs (which is WASAPI Exclusive).
Try the official ASIO output: https://www.foobar2000.org/components/view/foo_out_asio
Maybe the SACD input has to be configured to output to PCM? (I'm not actually using it, I don't have DSD files or a DAC).
Control Panel\All Control Panel Items > Sound > Device (iFi  Pro iDSD) Select > Properties > Advanced
▼ 768000 Hz or 384000 Hz Select > Test > OK
Confirmation:
foobar2000 Preferences > Playback > Output > ASIO or ASIO+DSD > ASIO Driver Double click > Sample Rate
foobar2000 Output: ASIO or ASIO+DSD
or
Resampler DSP (SSRC X) 0.57 (foo_dsp_ssrcX) x64
Download (Direct Link): https://foobar2000.xrea.jp/up/files/up1504.zip
x64\foo_dsp_ssrcX.dll > Preferences > Components > Installed components: Drag & Drop
DSP Manager > Active DSPs > Resampler (SSRC X)  ... click
bottom right: コンソールに情報を表示 → Menu > View Console
Output: ASIO
SHURE SRH1840, SENNHEISER HD660S, Beyerdynamic DT 1990 PRO, HIFIMAN HE5se, Ultrasone Performance 880, AKG K712 PRO, Bowers & Wilkins P7, SONY MDR-1AM2, Bose QuietComfort 45, SONY WH-1000XM3 (made a Upgrade/Balanced Cable by myself) Shall I write more?
Thanks, Gus! Give that a try and if that doesn't work I'll post a new thread on the forum here.
Thanks, Gus! I'll give that a try and if it doesn't work I'll post a new query on a new thread here in the forum.
