Topic: Disc ID/Track not present in AccurateRip database (Read 7167 times) previous topic - next topic
I ripped Guns N' Roses Appetite For Destruction but it says the Disc ID is not present in the database. The rip shows it was successful with no errors and it's probably a fairly common album. Is the start sector of 0 an issue or is my drive failing or something?
Edit: Added CUETools output.
Exact Audio Copy V1.3 from 2. September 2016
EAC extraction logfile from 21. February 2017, 15:55
Guns N' Roses / Appetite For Destruction
Used drive  : hp      CDDVDW SN-208FB   Adapter: 1  ID: 0
Read mode               : Secure
Utilize accurate stream : Yes
Defeat audio cache      : No
Make use of C2 pointers : No
Read offset correction                      : 6
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 1024 kBit/s
Quality                         : High
Add ID3 tag                     : No
Command line compressor         : C:\Program Files (x86)\Exact Audio Copy\Flac\flac.exe
Additional command line options : -8 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "BAND=%albuminterpret%" -T "ALBUMARTIST=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" %hascover%--picture="%coverfile%"%hascover% %source% -o %dest%
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  4:33.45 |         0    |    20519
        2  |  4:33.45 |  3:22.67 |     20520    |    35736
        3  |  7:56.37 |  4:28.38 |     35737    |    55874
        4  | 12:25.00 |  4:23.65 |     55875    |    75664
        5  | 16:48.65 |  3:48.67 |     75665    |    92831
        6  | 20:37.57 |  6:46.48 |     92832    |   123329
        7  | 27:24.30 |  3:39.45 |    123330    |   139799
        8  | 31:04.00 |  3:51.42 |    139800    |   157166
        9  | 34:55.42 |  5:56.33 |    157167    |   183899
       10  | 40:52.00 |  3:17.12 |    183900    |   198686
       11  | 44:09.12 |  3:26.30 |    198687    |   214166
       12  | 47:35.42 |  6:15.23 |    214167    |   242314
Track  1
     Filename C:\EAC Rips\01 Welcome To The Jungle.wav
     Pre-gap length  0:00:02.00
     Peak level 100.0 %
     Extraction speed 4.2 X
     Track quality 100.0 %
     Test CRC 22D0694B
     Copy CRC 22D0694B
     Copy OK
Track  2
     Filename C:\EAC Rips\02 It's So Easy.wav
     Pre-gap length  0:00:02.45
     Peak level 98.1 %
     Extraction speed 4.6 X
     Test CRC 4D32C531
     Copy CRC 4D32C531
     Copy OK
Track  3
     Filename C:\EAC Rips\03 Nightrain.wav
     Pre-gap length  0:00:01.37
     Peak level 98.2 %
     Extraction speed 4.9 X
     Test CRC B1C5FB65
     Copy CRC B1C5FB65
     Copy OK
Track  4
     Filename C:\EAC Rips\04 Out Ta Get Me.wav
     Pre-gap length  0:00:02.28
     Peak level 95.8 %
     Extraction speed 5.3 X
     Test CRC 05C373D3
     Copy CRC 05C373D3
     Copy OK
Track  5
     Filename C:\EAC Rips\05 Mr. Brownstone.wav
     Pre-gap length  0:00:03.70
     Peak level 100.0 %
     Extraction speed 5.6 X
     Test CRC 378E6E98
     Copy CRC 378E6E98
     Copy OK
Track  6
     Filename C:\EAC Rips\06 Paradise City.wav
     Pre-gap length  0:00:03.17
     Peak level 100.0 %
     Extraction speed 6.0 X
     Test CRC D6C34DD6
     Copy CRC D6C34DD6
     Copy OK
Track  7
     Filename C:\EAC Rips\07 My Michelle.wav
     Peak level 98.6 %
     Extraction speed 6.3 X
     Test CRC B5854051
     Copy CRC B5854051
     Copy OK
Track  8
     Filename C:\EAC Rips\08 Think About You.wav
     Pre-gap length  0:00:01.16
     Peak level 100.0 %
     Extraction speed 6.6 X
     Test CRC 479B9B87
     Copy CRC 479B9B87
     Copy OK
Track  9
     Filename C:\EAC Rips\09 Sweet Child O' Mine.wav
     Pre-gap length  0:00:01.32
     Peak level 100.0 %
     Extraction speed 6.9 X
     Test CRC 2DB187D9
     Copy CRC 2DB187D9
     Copy OK
Track 10
     Filename C:\EAC Rips\10 You're Crazy.wav
     Pre-gap length  0:00:01.60
     Peak level 98.5 %
     Extraction speed 7.0 X
     Test CRC 4862E8E1
     Copy CRC 4862E8E1
     Copy OK
Track 11
     Filename C:\EAC Rips\11 Anything Goes.wav
     Peak level 100.0 %
     Extraction speed 7.3 X
     Test CRC 706F954A
     Copy CRC 706F954A
     Copy OK
Track 12
     Filename C:\EAC Rips\12 Rocket Queen.wav
     Pre-gap length  0:00:01.14
     Peak level 100.0 %
     Extraction speed 7.6 X
     Test CRC 70A3EAF7
     Copy CRC 70A3EAF7
     Copy OK
None of the tracks are present in the AccurateRip database
No errors occurred
End of status report
---- CUETools DB Plugin V2.1.6
[CTDB TOCID: B2NhsXGi_LOitMeLGF567NcFJwU-] found
Submit result: B2NhsXGi_LOitMeLGF567NcFJwU- has been confirmed
Track | CTDB Status
  1   | (27/28) Accurately ripped
  2   | (28/28) Accurately ripped
  3   | (28/28) Accurately ripped
  4   | (28/28) Accurately ripped
  5   | (28/28) Accurately ripped
  6   | (28/28) Accurately ripped
  7   | (28/28) Accurately ripped
  8   | (28/28) Accurately ripped
  9   | (28/28) Accurately ripped
 10   | (28/28) Accurately ripped
 11   | (28/28) Accurately ripped
 12   | (28/28) Accurately ripped
==== Log checksum 0F488F5A3B84EB63DB5B8A205225DD1B6F124DA1CE0688CC157D8E11F19EC144 ====
[CUETools log; Date: 2/21/2017 4:39:21 PM; Version: 2.1.5]
[CTDB TOCID: B2NhsXGi_LOitMeLGF567NcFJwU-] found.
Track | CTDB Status
  1   | (28/29) Accurately ripped
  2   | (29/29) Accurately ripped
  3   | (29/29) Accurately ripped
  4   | (29/29) Accurately ripped
  5   | (29/29) Accurately ripped
  6   | (29/29) Accurately ripped
  7   | (29/29) Accurately ripped
  8   | (29/29) Accurately ripped
  9   | (29/29) Accurately ripped
 10   | (29/29) Accurately ripped
 11   | (29/29) Accurately ripped
 12   | (29/29) Accurately ripped
[AccurateRip ID: 00177f9b-00dc7542-b10c9e0c] disk not present in database.
Track Peak [ CRC32  ] [W/O NULL] [  LOG   ]
 --  100.0 [7A081C4E] [0F22B175]
 01  100.0 [22D0694B] [86884661]   CRC32
 02   98.1 [4D32C531] [52D155E5]   CRC32
 03   98.2 [B1C5FB65] [5A0C2842]   CRC32
 04   95.8 [05C373D3] [8E0E83B8]   CRC32
 05  100.0 [378E6E98] [E70D141A]   CRC32
 06  100.0 [D6C34DD6] [5F05FA5F]   CRC32
 07   98.6 [B5854051] [365163F2]   CRC32
 08  100.0 [479B9B87] [E2B4FC3D]   CRC32
 09  100.0 [2DB187D9] [F649447F]   CRC32
 10   98.5 [4862E8E1] [3D350CBC]   CRC32
 11  100.0 [706F954A] [E5EA200B]   CRC32
 12  100.0 [70A3EAF7] [418D7C08]   CRC32
Re: Disc ID/Track not present in AccurateRip database
I'd try to verify again later with CUETools. I had a similar rip a couple weeks ago. Checked later and there were entries in the database.
The other entries in the CUETools Database (CTDB) that match your rip begin April 2016 and all were ripped using EAC so it seems unlikely that none were submitted to AccurateRip.
Note: Yes it is a common album. Discogs and MusicBrainz show many versions of the CD. This one is your CD.
korth
Thanks Korth, that's the first major one I came across that had no entry in AR. I tried doing the offset "probing" but realized it doesn't work when it doesn't exist. :)
If I may ask how did you find the correct one? I went to MusicBrainz and did several searches trying to match data like you did but I'm not sure what you searched on or what field you used like TOCID in the tag field, etc. to find the correct release I had? That seems pretty handy to be able to do that.
For that link I used https://musicbrainz.org/cdtoc/xxx (only works if the Disc ID exists) where xxx is MusicBrainz Disc ID found in the CUETools Database (CTDB).
That CTDB page is from a link on http://db.cue.tools/?tocid=xxx where xxx is the CTDB TOCID from the EAC or CUETools log.
The layout of my CD is attached to quite a few releases
https://musicbrainz.org/cdtoc/q0cV.lsQS51N9BWUOvmE9hcCHKs-
korth
Thanks a bunch Korth, that's really slick! I see the differences are roughly 1 to 2 seconds on about half dozen tracks between the two layouts. You've been doing this a long time it looks from several of your posts.
We are battening down the hatches here as we have a big ol' blizzard coming through tonight/tomorrow. High winds and deep snow. The sad thing it doesn't really stop anything since it's the "norm" living in the frozen tundra of the upper midwest. I'm just about close enough to kick the dirt in Canada.
Korth is it alright to piggy back off this post for a quick question. I ripped Journey - Greatest Hits Live and Track 16 couldn't be verified as accurate but all other tracks are fine. I ripped it a few times and it passes the test and read CRC checks with no errors. I was wondering how one track "in the middle" can be off but all the others are fine? It seems like an odd thing as usually the CD is off as a whole and shows in CUETools as a different offset.
I keep thinking either EAC changed how it works and the CD wasn't ripped/read properly once upon a time or the CD layout has changed for this pressing? If it has changed due to different ripping/reading technique  wouldn't it be treated as different pressing as the CRC calculations for the whole CD would change?
It seems there are several pieces/factors to the log checksum or is my CD possibly a bad pressing? I've ran into a few pressings that are squeaky clean with not a scratch but just can't be ripped/verified that I right off as bad pressings. This one seems good but it's a new scenario for me being one track in the middle. I attached the logs below.
EAC Log:
EAC extraction logfile from 2. March 2017, 22:49
Journey / Greatest Hits Live
Used drive  : ATAPI  iHAS124  F  Adapter: 1  ID: 0
Read mode              : Secure
Defeat audio cache      : Yes
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : C:\Program Files\Exact Audio Copy\FLAC\FLAC.EXE
        1  |  0:00.00 |  4:10.32 |        0    |    18781
        2  |  4:10.32 |  5:19.50 |    18782    |    42756
        3  |  9:30.07 |  5:14.33 |    42757    |    66339
        4  | 14:44.40 |  7:10.52 |    66340    |    98641
        5  | 21:55.17 |  4:18.18 |    98642    |  118009
        6  | 26:13.35 |  5:36.07 |    118010    |  143216
        7  | 31:49.42 |  3:29.50 |    143217    |  158941
        8  | 35:19.17 |  3:13.50 |    158942    |  173466
        9  | 38:32.67 |  2:26.38 |    173467    |  184454
      10  | 40:59.30 |  3:14.02 |    184455    |  199006
      11  | 44:13.32 |  3:37.50 |    199007    |  215331
      12  | 47:51.07 |  4:05.45 |    215332    |  233751
      13  | 51:56.52 |  4:38.45 |    233752    |  254646
      14  | 56:35.22 |  5:25.53 |    254647    |  279074
      15  | 62:01.00 |  3:08.32 |    279075    |  293206
      16  | 65:09.32 |  5:34.48 |    293207    |  318304
      17  | 70:44.05 |  0:40.70 |    318305    |  321374
Track  1
    Filename E:\EAC Rips\01 Don't Stop Believin'.wav
    Peak level 100.0 %
    Test CRC 62952B18
    Copy CRC 62952B18
    Accurately ripped (confidence 2)  [A2A2BF54]  (AR v1)
    Copy OK
Track  2
    Filename E:\EAC Rips\02 Separate Ways (Worlds Apart).wav
    Peak level 100.0 %
    Extraction speed 5.2 X
    Track quality 99.9 %
    Test CRC 973B9CFA
    Copy CRC 973B9CFA
    Accurately ripped (confidence 2)  [34AD4C89]  (AR v1)
    Copy OK
Track  3
    Filename E:\EAC Rips\03 After The Fall.wav
    Peak level 100.0 %
    Extraction speed 6.5 X
    Test CRC E952289C
    Copy CRC E952289C
    Accurately ripped (confidence 2)  [741FB1D2]  (AR v1)
    Copy OK
Track  4
    Filename E:\EAC Rips\04 Lovin', Touchin', Squeezin'.wav
    Peak level 100.0 %
    Extraction speed 7.2 X
    Test CRC 8C633CE3
    Copy CRC 8C633CE3
    Accurately ripped (confidence 2)  [B40D58F6]  (AR v1)
    Copy OK
Track  5
    Filename E:\EAC Rips\05 Faithfully.wav
    Peak level 100.0 %
    Test CRC 1D5A7E5A
    Copy CRC 1D5A7E5A
    Accurately ripped (confidence 2)  [117761E5]  (AR v1)
    Copy OK
Track  6
    Filename E:\EAC Rips\06 Who's Crying Now.wav
    Peak level 100.0 %
    Extraction speed 7.8 X
    Test CRC DFD24F39
    Copy CRC DFD24F39
    Accurately ripped (confidence 2)  [D2107891]  (AR v1)
    Copy OK
Track  7
    Filename E:\EAC Rips\07 Any Way You Want It.wav
    Peak level 100.0 %
    Test CRC 72F103C0
    Copy CRC 72F103C0
    Accurately ripped (confidence 2)  [49DE4E36]  (AR v1)
    Copy OK
Track  8
    Filename E:\EAC Rips\08 Lights.wav
    Peak level 100.0 %
    Test CRC EEC41847
    Copy CRC EEC41847
    Accurately ripped (confidence 2)  [B1DA562D]  (AR v1)
    Copy OK
Track  9
    Filename E:\EAC Rips\09 Stay Awhile.wav
    Peak level 100.0 %
    Extraction speed 7.7 X
    Test CRC 386ADB3B
    Copy CRC 386ADB3B
    Accurately ripped (confidence 2)  [78609366]  (AR v1)
    Copy OK
Track 10
    Filename E:\EAC Rips\10 Open Arms.wav
    Peak level 100.0 %
    Extraction speed 8.1 X
    Test CRC 7C97DFCB
    Copy CRC 7C97DFCB
    Accurately ripped (confidence 2)  [8FD82344]  (AR v1)
    Copy OK
Track 11
    Filename E:\EAC Rips\11 Send Her My Love.wav
    Peak level 100.0 %
    Extraction speed 8.5 X
    Test CRC 695F24DD
    Copy CRC 695F24DD
    Accurately ripped (confidence 3)  [8217E8B7]  (AR v1)
    Copy OK
Track 12
    Filename E:\EAC Rips\12 Still They Ride.wav
    Peak level 100.0 %
    Extraction speed 9.0 X
    Test CRC 574213AD
    Copy CRC 574213AD
    Accurately ripped (confidence 2)  [7996544B]  (AR v1)
    Copy OK
Track 13
    Filename E:\EAC Rips\13 Stone In Love.wav
    Peak level 100.0 %
    Extraction speed 9.4 X
    Test CRC DF785B41
    Copy CRC DF785B41
    Accurately ripped (confidence 2)  [BE8F15D1]  (AR v1)
    Copy OK
Track 14
    Filename E:\EAC Rips\14 Escape.wav
    Peak level 100.0 %
    Extraction speed 8.6 X
    Test CRC 933D835E
    Copy CRC 933D835E
    Accurately ripped (confidence 2)  [BA6C7DBA]  (AR v1)
    Copy OK
Track 15
    Filename E:\EAC Rips\15 Line Of Fire.wav
    Peak level 100.0 %
    Extraction speed 9.5 X
    Test CRC E3C73CA8
    Copy CRC E3C73CA8
    Accurately ripped (confidence 2)  [D1166297]  (AR v1)
    Copy OK
Track 16
    Filename E:\EAC Rips\16 Wheel In The Sky.wav
    Peak level 100.0 %
    Extraction speed 9.1 X
    Test CRC C0B0E782
    Copy CRC C0B0E782
    Cannot be verified as accurate (confidence 15)  [9DA33A36], AccurateRip returned [9B5A9301]  (AR v2)
    Copy OK
Track 17
    Filename E:\EAC Rips\17 Fireworks & Crowd (Untitled Hidden Track).wav
    Peak level 100.0 %
    Extraction speed 6.4 X
    Test CRC F392F298
    Copy CRC F392F298
    Accurately ripped (confidence 2)  [D7B3DBBC]  (AR v1)
    Copy OK
16 track(s) accurately ripped
 1 track(s) could not be verified as accurate
Some tracks could not be verified as accurate
No errors occurred
[CTDB TOCID: rfoIxZgWqbxJSzdvHD_7388hRXs-] found
Submit result: rfoIxZgWqbxJSzdvHD_7388hRXs- has been confirmed
Track | CTDB Status
  1  | (36/38) Accurately ripped
  2  | (37/38) Accurately ripped
  3  | (37/38) Accurately ripped
  4  | (37/38) Accurately ripped
  5  | (36/38) Accurately ripped
  6  | (36/38) Accurately ripped
  7  | (37/38) Accurately ripped
  8  | (36/38) Accurately ripped
  9  | (37/38) Accurately ripped
 10  | (36/38) Accurately ripped
 11  | (36/38) Accurately ripped
 12  | (36/38) Accurately ripped
 13  | (36/38) Accurately ripped
 14  | (36/38) Accurately ripped
 15  | (36/38) Accurately ripped
 16  | (34/38) Accurately ripped, or (1/38) differs in 14 samples @00:06:46-00:06:47
 17  | (35/38) Accurately ripped
==== Log checksum 1D31FEB62B55F6DE5C8D395D4C9FC4DEFA9CC2B58D036C6E10CA8709997F0B3D ====
CUE Tools log:
[CUETools log; Date: 3/3/2017 5:26:14 PM; Version: 2.1.5]
[CTDB TOCID: rfoIxZgWqbxJSzdvHD_7388hRXs-] found.
Track | CTDB Status
  1  | (38/40) Accurately ripped
  2  | (39/40) Accurately ripped
  3  | (39/40) Accurately ripped
  4  | (39/40) Accurately ripped
  5  | (38/40) Accurately ripped
  6  | (38/40) Accurately ripped
  7  | (39/40) Accurately ripped
  8  | (38/40) Accurately ripped
  9  | (39/40) Accurately ripped
 10  | (38/40) Accurately ripped
 11  | (38/40) Accurately ripped
 12  | (38/40) Accurately ripped
 13  | (38/40) Accurately ripped
 14  | (38/40) Accurately ripped
 15  | (38/40) Accurately ripped
 16  | (36/40) Accurately ripped, or (1/40) differs in 14 samples @00:06:46-00:06:47
 17  | (37/40) Accurately ripped
[AccurateRip ID: 002f98d0-024f782d-ec10bd11] found.
Track  [  CRC  |  V2  ] Status
 01    [a2a2bf54|287a3a7e] (02+00/58) Accurately ripped
 02    [34ad4c89|876da40d] (02+00/59) Accurately ripped
 03    [741fb1d2|8125c625] (02+00/59) Accurately ripped
 04    [b40d58f6|71d0f238] (02+00/58) Accurately ripped
 05    [117761e5|f2e50c9a] (02+00/59) Accurately ripped
 06    [d2107891|5bb7276b] (02+00/59) Accurately ripped
 07    [49de4e36|21fc85ce] (02+00/59) Accurately ripped
 08    [b1da562d|a42f5d0b] (02+00/59) Accurately ripped
 09    [78609366|5d34d15c] (02+00/59) Accurately ripped
 10    [8fd82344|fc5c9d0a] (02+00/59) Accurately ripped
 11    [8217e8b7|b354d0e9] (03+00/60) Accurately ripped
 12    [7996544b|867c7414] (02+00/59) Accurately ripped
 13    [be8f15d1|3104a0ab] (02+00/58) Accurately ripped
 14    [ba6c7dba|c30e47a6] (02+00/57) Accurately ripped
 15    [d1166297|5e7948bf] (02+00/57) Accurately ripped
 16    [f8ef8f26|9da33a36] (00+00/56) No match
 17    [d7b3dbbc|5ed3d225] (02+00/57) Accurately ripped
Offsetted by 758:
 01    [f97d2725] (04/58) Accurately ripped
 02    [90567770] (04/59) Accurately ripped
 03    [d4af497f] (04/59) Accurately ripped
 04    [33e44332] (04/58) Accurately ripped
 05    [2bdda87d] (04/59) Accurately ripped
 06    [96fe381b] (04/59) Accurately ripped
 07    [a41ed55b] (04/59) Accurately ripped
 08    [7e160bbb] (04/59) Accurately ripped
 09    [4baa10d4] (04/59) Accurately ripped
 10    [0922d02b] (04/59) Accurately ripped
 11    [d7680c9e] (04/60) Accurately ripped
 12    [fa6320df] (04/59) Accurately ripped
 13    [dfa9a8a8] (04/58) Accurately ripped
 14    [e2e33774] (03/57) Accurately ripped
 15    [85fa17df] (04/57) Accurately ripped
 16    [a69acd82] (04/56) Accurately ripped
 17    [0504c983] (03/57) Accurately ripped
Offsetted by 798:
 01    [3b0249eb] (06/58) Accurately ripped
 02    [58d4f5fd] (07/59) Accurately ripped
 03    [5b730ee8] (07/59) Accurately ripped
 04    [e19648be] (07/58) Accurately ripped
 05    [95a1eede] (07/59) Accurately ripped
 06    [37071a44] (07/59) Accurately ripped
 07    [a1b073a9] (07/59) Accurately ripped
 08    [ac94be3e] (07/59) Accurately ripped
 09    [6e724874] (07/59) Accurately ripped
 10    [7b8f2281] (07/59) Accurately ripped
 11    [a1af75cb] (07/60) Accurately ripped
 12    [8d0a89b2] (07/59) Accurately ripped
 13    [e5ea1f2e] (07/58) Accurately ripped
 14    [a15757e5] (07/57) Accurately ripped
 15    [f9ce4b97] (07/57) Accurately ripped
 16    [c50ba4c9] (07/56) Accurately ripped
 17    [e4044794] (07/57) Accurately ripped
Offsetted by 871:
 01    [97f4021f] (16/58) Accurately ripped
 02    [e2f97dac] (16/59) Accurately ripped
 03    [d69f495f] (16/59) Accurately ripped
 04    [d1253087] (15/58) Accurately ripped
 05    [7c6b69e0] (16/59) Accurately ripped
 06    [a58c4c6f] (16/59) Accurately ripped
 07    [d2aa0b44] (16/59) Accurately ripped
 08    [f0406943] (16/59) Accurately ripped
 09    [e2c912ce] (16/59) Accurately ripped
 10    [2f47dd1c] (16/59) Accurately ripped
 11    [e6b8b62b] (16/60) Accurately ripped
 12    [f04fcbce] (16/59) Accurately ripped
 13    [5ed9c34e] (15/58) Accurately ripped
 14    [b161be0c] (15/57) Accurately ripped
 15    [2e9d4fc6] (14/57) Accurately ripped
 16    [9b5a9301] (15/56) Accurately ripped
 17    [f8b86d5e] (15/57) Accurately ripped
Offsetted by 992:
 01    [3a7f0f7d] (06/58) Accurately ripped
 02    [9d55412d] (06/59) Accurately ripped
 03    [cd211e45] (06/59) Accurately ripped
 04    [7c728abe] (06/58) Accurately ripped
 05    [22d10be8] (06/59) Accurately ripped
 06    [ccaeef91] (06/59) Accurately ripped
 07    [1b8c354f] (06/59) Accurately ripped
 08    [6079bcad] (06/59) Accurately ripped
 09    [9b6ca51f] (06/59) Accurately ripped
 10    [5ef06c44] (06/59) Accurately ripped
 11    [545f6b6a] (06/60) Accurately ripped
 12    [62d78c01] (06/59) Accurately ripped
 13    [d80e4c92] (06/58) Accurately ripped
 14    [efcb8883] (06/57) Accurately ripped
 15    [1ab421b8] (06/57) Accurately ripped
 16    [07b25683] (06/56) Accurately ripped
 17    [aece5cc6] (06/57) Accurately ripped
Offsetted by 1235:
 01    [4770b243] (03/58) Accurately ripped
 02    [975d5460] (03/59) Accurately ripped
 03    [f57432d9] (03/59) Accurately ripped
 04    [defb8270] (03/58) Accurately ripped
 05    [7a16a223] (03/59) Accurately ripped
 06    [c687ac98] (03/59) Accurately ripped
 07    [240f8133] (03/59) Accurately ripped
 08    [bd179afb] (03/59) Accurately ripped
 09    [5b955106] (03/59) Accurately ripped
 10    [53027a52] (03/59) Accurately ripped
 11    [bfdd3629] (03/60) Accurately ripped
 12    [80d0d868] (03/59) Accurately ripped
 13    [f71db66e] (03/58) Accurately ripped
 14    [e1c281da] (03/57) Accurately ripped
 15    [f9aa3b1c] (03/57) Accurately ripped
 16    [4b7480ca] (03/56) Accurately ripped
 17    [28615b65] (03/57) Accurately ripped
Offsetted by 224:
 01    [d3df8375] (00/58) No match (V2 was not tested)
 02    [5f176839] (00/59) No match (V2 was not tested)
 03    [9682a245] (00/59) No match (V2 was not tested)
 04    [38dbffa5] (00/58) No match (V2 was not tested)
 05    [674ea61e] (00/59) No match (V2 was not tested)
 06    [3bf0a4fb] (00/59) No match (V2 was not tested)
 07    [4840025b] (00/59) No match (V2 was not tested)
 08    [9c5426fa] (00/59) No match (V2 was not tested)
 09    [1fd3156c] (00/59) No match (V2 was not tested)
 10    [a418ed75] (00/59) No match (V2 was not tested)
 11    [780016e5] (00/60) No match (V2 was not tested)
 12    [2db1b7d0] (00/59) No match (V2 was not tested)
 13    [8605531f] (00/58) No match (V2 was not tested)
 14    [968cb17b] (00/57) No match (V2 was not tested)
 15    [92ae5309] (00/57) No match (V2 was not tested)
 16    [df7c9dff] (00/56) No match (V2 was not tested)
 17    [5abb9d80] (00/57) No match (V2 was not tested)
Offsetted by 491:
 01    [4a712422] (00/58) No match (V2 was not tested)
 02    [af90e3fe] (00/59) No match (V2 was not tested)
 03    [99b8e722] (00/59) No match (V2 was not tested)
 04    [7f67c41f] (00/58) No match (V2 was not tested)
 05    [8d2cb0d3] (00/59) No match (V2 was not tested)
 06    [5ddc83a1] (00/59) No match (V2 was not tested)
 07    [e6dce57e] (00/59) No match (V2 was not tested)
 08    [5cbe7dc3] (00/59) No match (V2 was not tested)
 09    [fd6a0dc8] (00/59) No match (V2 was not tested)
 10    [4ecdc6a4] (00/59) No match (V2 was not tested)
 11    [52bc9b47] (00/60) No match (V2 was not tested)
 12    [d063347f] (00/59) No match (V2 was not tested)
 13    [6c7ad6e6] (00/58) No match (V2 was not tested)
 14    [1f985b18] (00/57) No match (V2 was not tested)
 15    [9982cce0] (00/57) No match (V2 was not tested)
 16    [7b234486] (00/56) No match (V2 was not tested)
 17    [e33f54d1] (00/57) No match (V2 was not tested)
 --  99.9 [6D28A361] [CF2DAD51]
 01  99.9 [62952B18] [0D212AC4]  CRC32
 02  99.9 [973B9CFA] [6ED02EB8]  CRC32
 03  99.9 [E952289C] [10190384]  CRC32
 04  99.9 [8C633CE3] [376551FC]  CRC32
 05  99.9 [1D5A7E5A] [DE1CDDC3]  CRC32
 06  99.9 [DFD24F39] [221DF287]  CRC32
 07  99.9 [72F103C0] [236295A7]  CRC32
 08  99.9 [EEC41847] [383C59EF]  CRC32
 09  99.9 [386ADB3B] [37C60212]  CRC32
 10  99.9 [7C97DFCB] [81D3E237]  CRC32
 11  99.9 [695F24DD] [26CE4C56]  CRC32
 12  99.9 [574213AD] [0395DEE8]  CRC32
 13  99.9 [DF785B41] [13129E05]  CRC32
 14  99.9 [933D835E] [0995CC28]  CRC32
 15  99.9 [E3C73CA8] [A874DA00]  CRC32
 16  99.9 [C0B0E782] [A01BFCBA]  CRC32
 17  99.9 [F392F298] [9554119E]  CRC32
[ode]
When AccurateRip only has two submissions and they don't match, both are removed and placed in limbo until a match to one is submitted. Then the two that match go into the database.
All the other tracks for your pressing are confidence 2 so there could be 2 entries for track 16 (for that pressing) that were moved into limbo because they didn't match each other. CUETools shows your rip matches multiple alternate pressings so you're good.
korth
Ah, thanks Korth, I suppose that CD had a scratch or damage of some sort to that particular track but the rest of the CD was fine and with limited database entries it's a "budding" verification! ;) . You have an easy way of explaining things that really makes sense.  Lately I've been really getting into live CD's from some of the "old" bands. Not sure if that's a midlife crisis thing as I watch the bands from our era age...
Hey Korth, may I run a quick question by you. It may have been happening on other CD's but I only noticed it on a recent rip. I was ripping Frank Sinatra - Best Of The Best (2011 US release) and tracks 1 through 12 had ISRC information but at 13 it started the grind which I usually take as no ISRC information. After taking a look at the CUE sheet it did have ISRC information for tracks 1 through 12 only and 13 through 23 it had none. Is that normal to only have partial codes on certain CD's?
Also just curious can you modify any tag information on tracks after a rip and still pass AR verification with CUETools or does the track/CD CRC change and it will fail? AR verification does require the log to be present and unmodified?
I have 100% accuracy on my rips so far but it required my to repurchase some. I've definitely missed my mark on certain tag information like genre and year. I go back and forth but some CD's that have been reissued 30 times (Christmas CD's seem terribly troublesome in this area ;)). I usually put the release year. It seems some of the old time singers like Frank Sinatra, Bing Crosby, Burl Ives, etc. originally started as vinyl and worked there way through all the medium types being remastered, reissued, added tracks, different covers, etc. and it's a bit daunting at times on what's the best way to go about the year. If there's enough new content/changes do I add the newer year or just stick with the original release year.
I guess long story short if I change my mind later on possible changes/corrections is it best to leave the original rips as "masters" or can the tag info be updated and still pass as 100% accurate with CUETools?
This is getting pretty far off topic.
You can modify the tags.
korth
Ok, sorry Korth, I will start a new topic.
To the point that it can't be successfully extracted without errors?
This clearly isn't the case at all...
Track | CTDB Status
Offsetted by 758:
Offsetted by 798:
Offsetted by 871:
Offsetted by 992:
Offsetted by 1235:
(log edited to remove extraneous and obfuscating information leading to possible confusion)
Korth already told you as much:
