Is there option for speed up music in foobar?
For ex. 1.25x 2x times faster.
https://www.foobar2000.org/components/view/foo_dsp_effect ?
Yes. Thank you for your answer. Effect is fine, but how to set shortcut to make inrease or decrease tempo effect? I cannot find proprer effect in shortcuts menu
You can add UI element for this. Or add shortcut to display floating UI element for this control (View > DSP > Playback rate).
Yes it works. Thanks
