Topic: 5.1 to 2 channel downmix (Read 9151 times) previous topic - next topic
some question regarding 5.1 to 2 channel (azidts)
is it correct in 5.1->2 downmixing, my instinct tells me it is incorrect
I've uploaded 2 sound capture, one from windvd
and the other one is produced by azidts
1st gunshot is OK
Listen carefully to the 2nd gun shot in each track
after the gun shooting sound, the water splashing is downmixed
quite different with windvd and azidts
WinDVD's water splashing sound is from the left channel only
while azidts is in the right channel!!
which is right and which is wrong?, my instinct tells me windvd is right, the water splashing hapens in the left half screen (bad describtion, hope u understand what i wanted to express)
Samples
I use besweet GUI
these are the checked setings
LFE to LR -3db
Surround downmix 0db
normalize
hybridgain, that's all, other checkbox are not checked
There is the downmix method on some property page. Find it and try if it helps you.
I figured out,
if dolby compatible downmix is used, the splashing sound will come out of the right channel
if stereo is selected, it will be from the left!!
so dolby or stereo? I thought dolby is more accurate than just stereo?
2.      besides, Foobar also has 5.1 ->2 ch, and the DTS decoding speed is much faster than besweet
Besweet can encode DTS at  realtime, which is very slow
is foobar2000 downmix dolby compatible or it's just simple stereo?
3.      or maybe i can just use HE-AAC at 96kbps? for 5.1? then I won't face all those downmixing headache
is He-AAC supported by matroska container! I don't want to end up playing back HE-AAC without SBR (it sounds awful)
Dolby modes allow your home theater rig to extract extra channels from your two channel source.
96 kbps he aac isn't enough for 5.1 sound. I'd use at least 160 or 192 kbps. Matroska supports even he aac + ps.
I've tried to encode short files, and Internet (~128kbps) has echo which is too long and abvious enough, very annoying!
streaming (~167kbps), iss acceptable!
annyway what's PS
And is it recommended to check the so called "PNS"????
Don't know about pns but ps (parametric stereo) isn't even available yet.
PS, is it something like SBR, SBR is for frequency and PS is for channels?
i know mp3pro has this too, it save files in mone and playback in stereo?
about PNS thing, I think i need to start a new topic in aac section, i van & menno would surely know the answer
