Topic: How to convince people to stop MP3 myths (Read 62656 times) previous topic - next topic
 Has anyone ever had a hard job trying to dispell certain mp3 myths? Like:
1) Joint Stereo messes up the sound.
2) Joint Stereo ruins high frequencies.
3) You can always tell the difference.
etc etc.
I feel like I'm bashing my head against a brick wall trying to talk to these people...
Oh, I think we're all pretty familiar with your problem. Your best bet is to have a read through the FAQs here, they cover some of the issue's you mention. Also, read up on ABX testing (also covered in a FAQ) and point the naysayers towards that FAQ and ask for ABX results.
daefeatures.co.uk
Don't worry.  I can assure you you're not the only one who has come across the problem of others' ignorance and general not caring about the subjects.  Both this and VBR are touchy subjects people are stubborn about.
You know how I combat this one as well as people saying VBR isn't of high quality?  It's simple.  I ask them "If it destroyed quality then why are both VBR and forms of joint stereo used in lossless codecs?"
About the best you can do really.
Nero AAC 1.5.1.0: -q0.45
[a href="index.php?act=findpost&pid=277196"][{POST_SNAPBACK}][/a]
I've seen people say that they don't need to ABX as they can hear the problem!
etc etc.
[a href="index.php?act=findpost&pid=277194"][{POST_SNAPBACK}][/a]
Easiest way: perform public listening tests & prove your claims. Simple.
Still, there's people that will never be convinced.
I have seen people unable to ABX, still think that their files have "something" that they cannot put their finger on.
I'm the one in the picture, sitting on a giant cabbage in Mexico, circa 1978.
Reseñas de Rock en Español: www.estadogeneral.com
etc etc.
MP3 are crap
Simplest way: switch to Vorbis
The general situation I have found is "Why encode at higher bitrates when 128kbps is just the same as the original".
I don't even care about trying to dispel these myths. People are happy believing them and encoding their music with them, so let them be.
The only reason I believe there would be for trying to dispel those myths is if you guys were into heavy file sharing...
IMHO, it is now impossible to dispel the JS-myth on a large scale.
The only solution is disabling the switch completely in LAME.
- Lyx
The only reason I believe there would be for trying to dispel those myths is if you guys were into heavy file sharing... :rolleyes:
[a href="index.php?act=findpost&pid=277243"][{POST_SNAPBACK}][/a]
So, do you think that all non-selfencoded MP3s are illegal? May i remind you about netlabels, artists who give their music or some tracks away for free and taped live-shows?
- Lyx
The only solution is disabling the switch completely in LAME.[a href="index.php?act=findpost&pid=277262"][{POST_SNAPBACK}][/a]
I'll second that
Or to have user interfaces similar to this one:
http://lame.sourceforge.net/lame_ui_example.html
[a href="index.php?act=findpost&pid=277268"][{POST_SNAPBACK}][/a]
Hmm, isn't this essentially the same? The stereo-option is just hidden in the frontend, making it appear as if lame doesn't have this option - the net result is removing the stereo-switch - but with the difference that the app needs to "support" it. I have reasonable doubt that the majority of the authors of the existing apps will understand that removing an already existing option is an improvement.
- Lyx
particularly, the myths that I more hate are these:
1) 128 CBR kbps mp3 is CD quality
2) Joint stereo is bad, because destroys all the stereo information.
3) Simple stereo is the best choice, because preserve all the stereo information.
4) mp3 never is or will be transparent.
5) VBR thing is bad, CBR is a lot better.
6) 192 CBR kbps mp3 in simple stereo mode is the best solution for archival quality.
7) Fhg is the best mp3 encoder.
All these myths come from the ignorance. I try to convince to my friends that they are wrong, but; it's impossible
I just don't bother educating people anymore. I just ignore them. It's too frustrating, and you can't educate everyone. Educating one clueless moron, is like a drop in the sea of morons.
What does bother me however, is that the danish music paysites are using retarded LAME settings to encode their music, and that's really annoying. If they sold --aps MP3 or even just properly encoded 192 CBR MP3, I'd consider using them.
I even tried sending them a mail, and explaining the situation to them, giving helpful links etc., but all I got in return was some standard bullshit reply.
All these myths come from the ignorance. I try to convince to my friends that they are wrong, but; it's impossible crying.gif
Personally if my friends don't listen to what I want I just to tell them to go F off. People are generally dumb, ignorant, and foolish are not going to listen to you anyway no matter what reasonable explanation you have for them they generally don't care.  That's why we have our uber-pretentious community here of course ;-D.  The only thing you can really do is "educate" the uninformed public and hope they listen.
budding I.T professional
I'd just get rid of the stereo switch and re-name joint-stereo to 'stereo' - or map the stereo switch to joint-stereo
Sure, why would we care? Well, since all the other 'modern' codecs already use Joint-Stereo as default and call it 'Stereo' some newbie will actually believe that mondern codecs are far better than mp3...simply because they don't how to encode in mp3...
You cant convince people that something is terrible if they cant notice. So I dont try to dispell myths. If they really want to know information(or truth about audio coding), they probably will search for themselves.
Alguém pare o mundo que eu quero descer!!
Or maybe we should map Joint Stereo as Good Modern Stereo and "normal" stereo as Bad Old Stereo. This way, maybe placebo will help us for once.
It is not your obligation to educate anyone until they notice skips from using sync or burst mode, clips and chirps from other corruption, garbly artifacts, etc., and want to get it done right.
Note: this is coming from a previous ToS #8 violator , who originally believed it all...until hundreds (maybe thousands, really) of hours of listeing began to train his brain into having good ears.
My opinion is that MP3 encoding washes out the high range. I prefer to encode my signals with ogg vorbis of quality 7 or higher, just to be safe.
As well, I generally avoid playing MP3 files that are less than 256 kbps CBR or 192kbps VBR at high volumes or in a performance situation. I once read that exposure to low quality lossy encodings can cause cumulative hearing loss and tinnitus. While I can not say if that is true, I prefer to err or the side of caution.
[a href="index.php?act=findpost&pid=277443"][{POST_SNAPBACK}][/a]
Troll?
Don't exist scientific evidence that supports this.. (or at least credible).
This is another new myth that we can add to the list.
[a href="index.php?act=findpost&pid=277281"][{POST_SNAPBACK}][/a]
This one is actually kinda true.
CBR (320K/-api) is the VERY best LAME has to offer. It is overkill though, and it is not like I can hear a difference (my transparency thresold is about 160k in LAME)
Although you will not catch me dead telling that to my friends or anyone else.
