Topic: Discussion of "Default UI Gallery" (Read 298316 times) previous topic - next topic
Re: Discussion of "Default UI Gallery"
Reply #650
Amazing ! Thanks Coreda for the link.
Unfortunately I don't see any folder support for JS Smooth Playlist Manager ?
Reply #651
Can't recall which features it has off-hand, it's fairly basic. What do you mean by playlist folders btw?
Reply #652
Folders containing playlists ? A way to group playlists.
Reply #653
I was just really satisfied with the program and decided to share my theme  :)
Screenshot of 1080p wide display, the theme file (orangin.fth) is included.
You can simply load it as is, doesn't use any other dependency (only the tray icon is linked to different foobar2000 program files ico).
Screenshot is from v1.3.14 but works with v1.3.16 as well.
Cheers!
Reply #655
I'm using SimPlaylist
I can't remember anymore if this is one of the predefined Group setting, or a modified template - anyway here a screenshot of the Group settings:
.halverhahn
Reply #658
It's a second Biography Panel switch by Album Cover without last.fm infos...
Reply #660
Hi - what are the spectrum and VU meters that you are using here?
https://hydrogenaud.io/index.php/topic,58574.msg953285.html#msg953285
Oh, those? Peakmeter Spectrum Visualisation. I think it's on the list of unstable components, but for me it works just fine. Normally there are both peakmeter and spectrum in one window, but you can configure it to be only one of them.
Error 404; signature server not available.
Reply #663
I've got a solvable problem I hope, I just don't known enough to figure it out myself. I've been using foobar mainly for format conversions and tagging. I now want to use it as a media player. My problem is the album list, last week I added my media server to the library after an hr or so I had a list of 4800 albums this is way too many items to scroll through, I'd like to just see a list of artists then be able to expand to a list of albums under each artist. From screen shots I've seen in earlier posts I know this configuration is possible. Any help would be appreciated.
Reply #664
Open Preferences -> Media Library -> Album List and create a display pattern. You can use "by artist/album" as a starting point, copy and expand it depending on the tagging standards you follow. To put artist and album on separate levels, insert a vertical bar character "|" between them.
[%album artist%|]['['%date%']' ]%album%|[[%discnumber%.]%tracknumber%. ][%track artist% - ]%title%
Reply #665
Thank you for the info I didn't know about the function of the vertical bar and I take it that the bar has to be between "%" and the"]"
Is there a list of operators and all of their functions? I've looked throughout the wiki but can't find anything.
I modified the script you shared slightly, I just want the artist on top and I don't want the date next in the hierarchy.
I loaded it and it's very close to perfect. Only problem is it shows all my tagging shortcoming.
[%artist%|][%album%|][[%discnumber%.]%tracknumber%. ][%track artist% - ]%title%
Thanks Again
Reply #666
...didn't know about the function of the vertical bar and I take it that the bar has to be between "%" and the"]"
Is there a list of operators and all of their functions?...
That vertical bar is called a pipe. A supplement to the Query Syntax page is Titleformat Album List
A foobar enthusiast who's neither an audiophile, nor an album snob.
Ever notice whenever there is a thread mentioning track ratings, someone will inevitably come in to post that they don't use ratings or believe in rating music?
Reply #667
A vertical bar can be anywhere you want. If it is inside square brackets, then it will not be output if the fields on that level were missing.
Reply #668
v1.6.6b5
Repeat the 11k&11k scale in the Spectrum.
