Topic: [solved] Color change problem (Read 2070 times) previous topic - next topic
This must be the most stupid bug i have ever seen.
I just cant change the third number in the colors changing options.
Here is a screenshot
I forgot to say that this is a completely clean install,o i'm thinking it can be caused by a windows file (but wich one?)
Have a look at the following Windows Registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\Current Version\FontSubstitutes
The value of the "MS Shell Dlg" key should be set to "Microsoft Sans Serif", while yours is apparently set to "Tahoma".
Thanks Frank
You've solved my problem
I can finally change the colors in my foobie
