Topic: $ifequal and non-integers (Read 1964 times) previous topic - next topic
i fear this might be obvious;
$ifequal only compares integers(...-1,0,1...) right?
so if you wanted to compare two non-integers like, just as an example
a variable you have set... $setpvar(title,%title%)
and the current playing title... %title%
how would you go about this?
To compare strings, use $strcmp or $stricmp. Read the titleformat reference for further information.
Example:
$if($strcmp(%title%,Whatever),Something,SomethingElse)
PS: I guess the $setpvar function has been introduced by a 3rd party component. Please do not assume that every forum member knows about that, and name the component and/or describe the function in detail.
dang, i knew it would be simple, sorry i overlooked it, there are just so many
and for those reading this that don't know, $setpvar and $getpvar are part of the Panels UI(foo ui panels) component
$setpvar[/color](name,value)
$getpvar(name)
  • Variable similar to common variable operations ($put, $puts & $get) plus the ability to keep permanently its value.
  • Can be set/accessed anywhere thoughout Panels UI (Panels UI itself + Track Display and Single Columns Playlist).
[/li][/list]
