Topic: MP3Gain 0.9.9 Beta (Read 4904 times) previous topic - next topic
MP3Gain 0.9.9 Beta
http://www.geocities.com/mp3gain
MP3Gain version 0.9.9 does not have any functional differences from 0.9.7.
It fixes some problems with double-byte character set (DBCS) file names, usually associated with Chinese, Japanese, and Korean files.
Version 0.9.9 also fixes a problem with 0.9.8 that made it freeze for Windows 95/98/ME users.
MP3Gain 0.9.9 Beta
Could you leave directions on how to move to be able to download?
I only get redirected to some horrible german MP3 page...
I don't think everyone udnerstands german
edit:
Haha.. silly me
Just use mirror 3 and avoid no. 1 if you don't know german.
MP3Gain 0.9.9 Beta
Once I used the programm with my files I can´t get Nero to burn them as an audio-cd. Does anyone know how to fix that.
WinXP, Nero 5.5.9.17.
MP3Gain 0.9.9 Beta
Will there be wav support in the future? I use vorbis now so the ability to normalize wav files would be nice.
MP3Gain 0.9.9 Beta
what? Normalization is bad.
Ogg Vorbis has vorbisgain which is even better constructed than mp3gain (it adds a gain "tag" instead of changing the global gain in every frame).
Vorbisgain is included with the vorbis tools @ www.vorbis.com
Use that instead for ogg vorbis. Do not normalize.
If you wanna do something similar with a wav file you can use wavgain.
MP3Gain 0.9.9 Beta
Is vorbisgain a separate program? Because I only have oggenc, oggdec, ogginfo, vcut, vorbiscomment, etc.
Also, where is the webpage for wavgain? I remember seeing it referenced along with mp3gain, but the version I saw was analysis-only (doesn't apply dB settings). Thanks
MP3Gain 0.9.9 Beta
really? oh no .... that means i cant burn the mp3s i gained??
are u sure?
MP3Gain 0.9.9 Beta
That's absolutely not true.  First off, I do it all the time.
Second, MP3Gain doesn't change the raw data at all.  All it does is change a value that tells each frame how much gain to apply.  This is no way affects the quality of the MP3.  This gain value is part of the MP3 standard and there's no *right* value for it.
MP3Gain 0.9.9 Beta
are u sure?
It's been quite a while since someone found a genuine "this is destroying my mp3 files" bug in mp3gain.
That's not to say it couldn't happen, but the likelihood is very strong that something else went screwy along the way.
pippi27, if you have some "before" and "after" copies of a single mp3 that can burn with Nero before MP3Gain and cannot burn after, I'd appreciate it if you could upload them somewhere where I can download them to test them.
-Glen
MP3Gain 0.9.9 Beta
I wouldn't go so far as to say it destroys the mp3 file, but sometimes it still strips id3 tags from files, though not often.  Perhaps a handful in a few thousand mp3s.
MP3Gain 0.9.9 Beta
Sigh.
If you have an actual "before" and "after" case where this is happening, PLEASE get a copy to me.
The code is designed to only change specific bytes in an mp3 file. It does not add unto nor take away from that which is written in the mp3 originally.
I can conceive of cases where the ID3v1 tag might get screwed up, but only if the original mp3 data is corrupted in precisely the right way and in the right place. That shouldn't be happening in a "handful in a few thousand mp3s".
-Glen
MP3Gain 0.9.9 Beta
ok, I'll try to figure out if I have a few specific cases, or if it's just random, and I'll post back here. might not be until after the weekend, working late hours this weekend and will probably be too tired to check it out after work.
MP3Gain 0.9.9 Beta
are u sure?
-Glen
@glen
If I slow my burner down, it´s working.
Still I get more "buffer-under-run" errors than before, even though buffer-under-run-protection is activated.
