Topic: 32kbps public listening test - OPEN (Read 53912 times) previous topic - next topic
Reply #75
Full ack!
Anyone noticed what you get when inverting end of both words?
Reading quickly, I get this one inverted. The meaning is then completely different.
Reply #76
According to the presentation page, only Vorbis got the special SSRC resampling. If so, was it checked and how and by who, that the other codecs using 32khz sampling didnt have resampling induced quality drop (like vanilla Vorbis) ?
[a href="index.php?act=findpost&pid=226243"][{POST_SNAPBACK}][/a]
Nobody showed up to test the other codecs. I am grateful (and the vorbis people should also be) to dev0 for checking it out.
Reply #77
Right. Imo then the correct procedure would have been to use SSRC for all the resamplings, or not use it at all. Now only one codec got the benefit just because someone happened to test it for Vorbis.
Juha Laaksonheimo
Reply #78
[a href="index.php?act=findpost&pid=226248"][{POST_SNAPBACK}][/a]
As I remember it, you mentioned SSRC resampling needed to be supported in a streaming software to make it's usage meaningful for this test.
dev0 found out it can be done for Vorbis with fb2k. It can't be done for WMA std and QDesign because neither windows media server nor Darwin streaming server use or support SSRC. Shoutcast (probably the most popular MP3 streamer, based on Lame) doesn't use SSRC either. Same thing about Real Broadcaster.
So there.
Reply #79
So there.
[a href="index.php?act=findpost&pid=226254"][{POST_SNAPBACK}][/a]
I said, at least, being a reason in order to justify the use of 3rd party component somehow. Before the test I privately said to you the same as here that all resampling should be done with SSRC or none at all. You said you can't consider any of my suggestions anymore because I'm too biased against Vorbis.
IIRC you also said that streaming server use isn't the point of this test, rather how the codec can do in best circumstances. Non-live streaming is perfectly possible for all codecs with SSRC.
Since the other codecs using resampling didnt get tested or treated equally to Vorbis, we can only hope that there's no resampling issues which would affect the results negatively for the other codecs.
Juha Laaksonheimo
Reply #80
Full ack!
[a href="index.php?act=findpost&pid=226245"][{POST_SNAPBACK}][/a]
That's exactly what I read first !
Reply #81
[a href="index.php?act=findpost&pid=226256"][{POST_SNAPBACK}][/a]
If Vorbis performs bad, nobody will care about it. If it comes first, for sure it's an issue !
Reply #82
IIRC you also said that streaming server use isn't the point of this test, rather how the codec can do in best circumstances. Non-live streaming is perfectly possible for all codecs with SSRC.[{POST_SNAPBACK}][/a]
True. But you gotta consider that I'm only one person that doesn't do listening tests himself and, particularly on this test, was on a limited time frame. In this aspect, Vorbis can be considered lucky that it had an enthusiatic individual that looked into this issue and found a solution. Unfortunately, WMA, Real and QDesign didn't have anyone to look out for them.
It's similar to the issue with the iTunes MP3 encoder in the MP3 listening test. There has been lots of speculation about iTunes maybe being better in CBR at 128kbps, but noone took the initiative to test VBR vs. CBR while the test was being discussed.
[a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=18378&view=findpost&p=181882]http://www.hydrogenaudio.org/forums/index....ndpost&p=181882[/url]
Reply #83
IIRC you also said that streaming server use isn't the point of this test, rather how the codec can do in best circumstances. Non-live streaming is perfectly possible for all codecs with SSRC.[a href="index.php?act=findpost&pid=226256"][{POST_SNAPBACK}][/a]
[a href="index.php?act=findpost&pid=226292"][{POST_SNAPBACK}][/a]
Imo it was not similar. In your example it was about internal encoding setting. In resampling issue it was about the use of external 3rd party component which is possible to use for all resampled codecs.
Juha Laaksonheimo
Reply #84
I thought this had been discussed into the ground a couple of pages ago?
Vorbis was the only encoder that was shown to have issues with its internal resampler, so there should be no need to use SSRC with the other codecs in the test.
< w o g o n e . c o m / l o l >
Reply #85
[a href="index.php?act=findpost&pid=226297"][{POST_SNAPBACK}][/a]
Eh, how do you know if there was need or not if it was not tested!
It is perfectly possible that this issue is a non-issue, but without testing we simply don't know, thus if not tested, we should treat the codecs equally. This is my opinion.
So, even if this resampling issue turned out to be irrelevant regarding the other codecs, this imo shows somewhat questionable testing practice, especially considering that there is a 3rd party component involved.
Juha Laaksonheimo
Reply #86
Ogg Vorbis is quite new, open source and it's development is in progress.
I understood the SSRC issue always in such a way, that for this test, Ogg Vorbis samples were prepared, that show the potential at 32 kbps in comparison to established codecs.
That's quite fair for a codec in development.
Reply #87
[a href="index.php?act=findpost&pid=226299"][{POST_SNAPBACK}][/a]
If you ask from Monty, he will tell you that Vorbis is about 10 years old project of his.
Juha Laaksonheimo
Reply #88
Ogg Vorbis is not the only codec that´s in development.
Reply #89
I was away (holiday) the last weeks. And now I would like to make the test, too. But in the first posting you write that the test is scheduled to end at July 11th but the title says "OPEN".
So is the test open or closed already?
Thanx
Big_Berny
Reply #90
Thanx
Big_Berny[a href="index.php?act=findpost&pid=226320"][{POST_SNAPBACK}][/a]
I plan to start calculating results this afternoon, so yes, you can pretty safely consider it closed :/
Reply #91
[a href="index.php?act=findpost&pid=226322"][{POST_SNAPBACK}][/a]
Wll, that's bad news... Sorry, that I couldn't do the test. I hope you have enough results!
Big_Berny
Reply #92
Still no results?
Reply #93
rjamorim you're being very quiet, you OK? or have you gone into shock cos of the results?
Reply #94
[a href="index.php?act=findpost&pid=227861"][{POST_SNAPBACK}][/a]
Too much wine at the family parties?
Reply #95
erhm... i know 56k is slow, but shouldn't the results be in by now?
anyway looking forward to the results, thanks for the effort.
Reply #96
Hope everything's OK.
Reply #97
me too, the suspense is killing me
Reply #98
[span style='font-size:8pt;line-height:100%']Off-topic posts split here.[/span]
Happiness - The agreeable sensation of contemplating the misery of others.
Reply #99
Hey, what happened to rjamorim? Now, even his website http://www.rjamorim.com/ is down.
EDIT: His site is online again
