Topic: why only 80 samples? (Read 3569 times) previous topic - next topic
When I encode a 160 samples frame by Speex, I get 38 bytes (char) as a result.
When I try to decode those 38 bytes back,  I expect 160 samples again and allocate the buffer for that. But after decompression only half of the buffer is filled with data (80 samples), the rest is filled with unknown values.  Why is that happening?  How am I supposed to decompress the frame correctly?
I would surmise that this is due to Speex resampling the data to 22kHz.  However that answer seems a little too easy.
resampling?  How's that possible?
I explicitile ask Speex to work in narrow_band mode (8000 Hz) because my signal is sampled with 8000 Hz rate
I take a PCM file, signed, 16 bit per sample.  Let's say the size of the file is 70K.  Encode with Speex (narrow band), decode back and get a file which size is twice bigger than original    Why is that happening?  I expected the size would be the same.
I don't get it... Speex says "I need 16 bits per sample, signed, PCM signal".  I create such file in audio editor.  After encoding, decoding the result is twice bigger, first. And second, the signal is absolutely distorted.
