Topic: Is foobar converting with command line possible ? (Read 363 times) previous topic - next topic
I wonder if it is possible to achieve some effect in foobar with command line.
I have folder with two files: MUSIC.FLAC and MUSIC.CUE.
Music .flac is one large file containing songs in flac format. After manually dragging the CUE file to Foob, they are all visible.
I want to convert one large MUSIC.FLAC file to separate FLAC files, on a 1 file 1 song basis. Manually it is a simple matter (drag the CUE into the foobar, select all files and CONVERT/flac). I wonder if it is possible to do the same with commandline (as part of the batch script).
Re: Is foobar converting with command line possible ?
Yes, I found this wiki page. I can start foobar and load cue files.
foobar2000.exe /add music.cue
Now I try to find command to convert it.
CueTool doesn't support 24bit. My FLAC file is 24bit.
CueTools is meant for working with CD audio, which is 44100/16/stereo, and nothing else.
